Makeshift Rg6 Water Line
Published
Introduction: Makeshift Rg6 Water Line
About: I was born and raised in Central Florida. I hold a bachelor's degree in business management and do network maintenance for a broadband/telecommunications company. I am married with two perfect girls. I ...
Step 1: Parts Needed
Rg6 compression fittings, f-type coupler (barrel), rg6 interior cable (not flooded!), wire cutters, compression tool, punch or #1 Philips screwdriver, hammer.
Step 2: Strip Wire
Wring one of the ends of the rg6 down to the copper and remove the jacket and braid. Hold onto the copper stinger and work the rest of the outer jacket away from the inside. The longer the piece of cable, the harder this will be and longer it will take. You have to run your hand all the way down the cable while pulling. Your end result should be an empty piece of tubing.
Step 3: Add Fittings
You can now slide your compression fittings onto the ends of the cable. Make sure they are seated all the way and crimp them down with your compression tool.
Step 4: Prep Coupler
You will need to remove the guts from the f-type coupler. To do this, locate the side that is not solid. It should have a ring around it. Face this side down and clamp it in a vice or in between your side cutters like I did. Take a punch, screwdriver, or drill bit and hammer down on the top. This should release the insides leaving you with a hollow coupler.
Step 5: Connect Everything and Let It Flow
You can now configure this however you need to get the job done. I used mine to transport hho gas from container to container. You can use couplers with a retaining nut on the back side to hold them tight inside of containers. I have not pressure tested this, but I imagine it won't hold much. I just use it for free-flowing and gravity-fed applications. Enjoy!
    • Casting Contest
      Casting Contest
    • Spotless Contest
      Spotless Contest
    4 Comments
    I love this. I want to set up small irrigation for my garden in progress but the cost of materials was a deterrent. I have tons of this cable laying around. Have you tried making small emitter holes along the casing to see how well it would work for that purpose?
    I have not tried it, but the jacket is fairly easy to puncture and I think it would work well as a drip hose. You may have a hard time stripping long pieces of cable. Maybe a bench vise would work well for holding the insides while you pull on the jacket. I'd be interested to see your finished product. Maybe I will try something similar for my wife's garden. Thanks for looking!!!
