Making 3D Objects From Foam Board
Published
Introduction: Making 3D Objects From Foam Board
About: I enjoy reading adventure books, building robots, cooking, and helping my Dad do just about any project he's working on.
In this instructable i am going to show you a method for making 3D objects from foam.
it is the same concept used in 3D printer slicer software to turn 3D designs in to a usable format that 3D printers can understand.
Step 1: Materials and Tools
Materials needed for this project:
Foam board (I found that 1/4 inch is a good size)
Hot glue sticks
Tools needed for this project:
Paper and pencil (to design you object)
Knife
Hot glue gun
Sandpaper
Step 2: Design Your Object
I made a simple flat top pyramid. but you could make other shapes.
Using the pyramid as an example. Lets say your foam is .25 inches thick and your object is one inch thick that means that your object will be four layers thick.
To begin draw steps over your old drawing as in the photograph above.
Measure the distance between each step.
Than draw out the distances between each step to size the layers as in the photograph above.
Step 3: Cut Out the Layers
Cut the layers out to the size determined in step two.
Step 4: Gluing the Layers
Then glue the layers together remember to center each layer on the lower layer.
Step 5: Sanding!
Carefully sand down the steps to resemble the desired shape.
And that's about it!
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    2 Discussions
    I wonder if it would be possible to get 3d printer slicer software to give the profiles for all the slices. Then they could go straight into the laser cutter .... and you could make massive items as if you had a giant 3d printer
