3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making 3D Stitches on Custom Vinyl Toy
In this tutorial, we will be using the Toy2r Egg Qee to create a three-dimensional stitch pattern. Were also going to bust the egg open to make it look like its oozing gooey stuff. You can do this design on just about any rounded surfaced vinyl toy. The Toy2r Earg Qee is another great platform to practice this on, and they're really cheap in case you screw up on the cutting part.
Materials:
1. Super Sculpey (not very much of it, perhaps an ounce or two)
2. Round small sculpting tool
3. DIY Toy (available at the Delicious Drips Store)
http://store.deliciousdrips.com/collections/d-i-y-2
4. Acrylic Paint
5. Brushes
6. Dremel with cutting bit
7. Heat gun
Precaution: When you cut into vinyl, it will create some fumes, so try to work in a ventilated environment during the cutting section of this tutorial. Or not&.your lungs.
Step 1Toy prep work
Toy prep work
Step 1: Etching the track
When you get your toy, use a pencil to draw the path of your stitch pattern out. Avoid doing sharp turns if possible but be creative about how your route it. You can either route it so that it intersects with itself, or you can just run a line that terminates any way you want.
After sketching it out, use a Dremel with a cutting bit to carve into the vinyl without carving through it. The cutting bit I used is shown in the background. It's basically a disc that is roughened. The key to doing this well is moving at a steady pace and making sure that you always have a good angle on the toy. You should find that the vinyl is etched really easily.
Step 2: Cut the Qee till he bleeds
Using the same Dremel bit, we find a place where we want our drips to ooze out of. Well etch a second line beneath our initial etching. On our second run around, we're going to apply a little more pressure at a higher RPM with the Dremel to actually cut the section out. Once the section is removed, you may have to pull it out of the inside of the Egg Qee.
4 comments
Jun 5, 2009. 7:51 PMvolquete says:
is a heat gun a blow dryer?
Dec 23, 2009. 5:23 PMHellchild says:
nope
Jun 5, 2009. 6:53 PMvolquete says:
i want to try this >.< sdded to my summer MAKE list...
Jun 5, 2009. 1:15 PMLuminousObject says:
This is so cool. I've never done anything to a vinyl toy like that before, but now I might have to try! Thanks for sharing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:DeliciousDrips
