Making A Box of Power
Sorry: this isn't a magical device to achieve superhuman abilities. Unless you count 'availability of 22 outlets and 2 light sockets' as a superhero trait:)
Important note: please ignore me when i say "you can experiment with plugging in multiple sources of current." read sneigke's comment below to understand why this is a dangerous/stupid idea!
Here's a video of this easy-but-fun project:
This and pretty much everything else I build are for sale as kits and finished projects at my site, dirtnail.com.
Why build this? Good question. For me, it was basically because I wanted to finish a cool-looking project and get an obscene number of available outlets in a day:)
Step 1Gather Your Materials, Tools
Here's the materials I used:
-A toolbox to ruin (or cardboard if you're ok w/ that:)
-Desired number of AC outlets
-Desired number of lightbulb sockets
-An AC on/off switch
-Some decent-gauge cable, to wire your outlets, etc. to each other
-Thicker gauge AC cord, to connect box of power to the wall. I used one from a broken surge protector.
And the tools:
-Piece of cardboard, or other suitable stencil material
-Pen/pencil/other writing instrument to use with your stencil on the side of the toolbox
-Utility blade, or something else to cut through the side of your toolbox
-Wire stripper
-Philips head screwdriver
31 comments
Apr 30, 2011. 9:21 PMfluxor says:
I'm sure someone else has commented, but you should work on the construction quality. Electrical tape is nice for insulating things, I don't think you should use it to hold things in place. Over time it will fail if you are asking it to serve a mechanical rather than electrical insulation based duty.
The box itself should have some kind of over current protection. Relying on what is installed at your apartment or house is really taking your life into your own hands. Even some of your larger Microwave ovens are only rated to 1200 watts. (As to feedback on the cord you are using)
Of course, this is just me, but that plastic toolbox isn't UL listed, I would feel much safer with a metal box for grounding purposes, combined with over current protection and some sort of GFCI, you could make this a much safer project.
Nov 22, 2010. 1:31 PMMACKattacksnipe says:
911 whats your emergency
----ummm my house is on fire
Jan 1, 2009. 5:34 PMboyrock375 says:
with that many outlets you cant use them all you will end up overloading the circuit and thripping the breaker or worse
Jun 2, 2009. 11:40 AMWesley666 says:
Ya, you will never be able to use this many outlets, but if you rewired your house with larger gauge cable and put in a larger breaker you could use some of them but there is no way in hell that you could use 22 sockets from one socket, it just can't be done. The only problem with rewiring your house is that it is hard and time consuming as well as your breakers wouldn't trip when you needed them to for normal appliances. Rewiring one socket with a bigger brealer would be good though, like I had to do for my welder.
Jul 6, 2009. 4:35 PMboyrock375 says:
the real problem is u would be drawing to many amps
May 25, 2008. 10:28 PMchief tyrol says:
I'll admit that I'm not an expert at electricity, but having that many outlets rigged in series, and then plugging it into the wall, seems like a fire hazard to me.
May 26, 2008. 3:34 AMkahles77 says:
i'm no expert either, but I'm sure your suppose to have a max of 10 outlets on a single breaker. and BTW, where is your ground wire? they are not there just for looks. But I do like LinuxH4x0r's comment about an inverter.
Jun 25, 2009. 4:52 AMCybergothiChe says:
that was too much about grounding...my head hurts...
Jul 21, 2008. 4:25 PMsneigke says:
I must comment on your comment in your video about "trying multiple sources" for higher current capability. Rule one: Don't do it! First, if you use two plugs into the same circuit, you have gained nothing. Rule two: you could kill yourself. Typical homes are provided with 220, 2 phase.. If you were to connect two plugs, and parallel both phases, you first, better make darned sure their in phase or you WILL melt down/pop breakers. Rule three: Connecting across phases can also fry everything in your box by hitting everything with 220VAC! Yes, I said 220. You can measure the voltage in your own house to verify this. There are circuits on both phases and if you measure the voltage between your "two sources", and they happen to be on opposite phases, you have made a deadly 220VAC box which will pop the bulbs in seconds, and fry anything plugged into it. Or, if you are lucky, you will parallel the two phases in opposite polarity, causing a direct short circuit between 220V and pray the main breakers pop in time! Just some words to the wise.
May 26, 2008. 10:19 AMkahles77 says:
I understand that you did your homework on this project, and wont overload the box. but there are others out there that will not, and decide to plug this system into a 20A breaker and start overloading wires. I can see someone taking it to a LAN party, and trying to plug 10 computers into this thing. As for grounding, the article you pointed me to states that if your in Europe, your fine, no grounding required, but the NEC requires outlets with a grounding plug to be grounded in the USA. Otherwise a good Instructable. I checked out your other Instructables, some good stuff.
May 12, 2009. 3:49 PMWesley666 says:
Were you drunk when you built this?
May 12, 2009. 3:50 PMWesley666 says:
Sorry, were you HIGH when you built this?
Sep 19, 2008. 7:01 AMDerin says:
1:get a faceplate for the outlets 2:use less outlets 3:use the ground Other than that,great,detailed instructable,well done!
May 25, 2008. 9:56 PMMr. Rig It says:
Dude? Come on Really? You didn't have a shirt on in your other video either. Don't you get it? No shirt, No Shoes, No Service. For the love of God your scaring the kiddies!
Jul 21, 2008. 8:25 AMsneigke says:
If ya don't like the channel, change it! Sounds like he's scaring You!
Jul 22, 2008. 9:38 PMMr. Rig It says:
Blaa blaa blaa that's all I'm hearing
Jul 24, 2008. 2:04 AMsneigke says:
Agreed.
Jul 14, 2008. 10:15 AMDerin says:
I always run naked in the house,so that would be No underwear,No pants,No shoes,No shirt,No service
Clothes suck!
May 25, 2008. 10:21 PMMr. Rig It says:
LOL, maybe you could make and ible for reasons why not to wear a shirt or how to go "Incredible Hulk" stlye.
Jun 6, 2008. 8:56 AMsherwin says:
most modern and safe extension cords come with 4 to 5 sockets only and each socket has its own fuse. these extension cords also have a device that trips the system in case something goes bad...
May 28, 2008. 9:00 PMuguy says:
This is one of the most insanely unsafe project I've come across in a while. Unprotected bulbs, outlets with no plates, no ground and a serious possibility of an overload. Also a terrible wasted of a nice tool box.
May 26, 2008. 3:43 PMSergeant Crayon says:
If that's safe, I'm an octopus.
Oh wait, it's in series? Never mind, that's just one outlet with a crapload of plugs. If you ever attempt to use all 22 plugs you'll end up with a drill clocking out at half an rpm. On the other hand, if you had wired it in parallel you'd end up with a pile of ash.
May 26, 2008. 12:29 PMPKM says:
Wait, what? The outlets are in series? That's not right at all! Then any time you have more than one thing plugged in there will be a voltage drop. You need to have the outlets wired in parallel or they won't work properly if more than one thing is plugged in. The "no more than 10 outlets on one circuit" rule does depend on what you have plugged in, in theory you can have as many as you want but need to be responsible with your power consumption. I'd suggest adding a circuit breaker so you don't keep blowing fuses in the box's plug, but of course this isn't an excuse to not have a fuse.
May 26, 2008. 5:26 AMupriverpaddler says:
I'll avoid any remarks about how safe or unsafe this is. But I will recommend that you Google "electrical safety" at least one time before attempting this.
That said, you could incorporate one of these..
http://www.kitsrus.com/pdf/k74v2.pdf
to be able to control the outlets via your PC.
May 25, 2008. 8:10 PMagdollison says:
put a damn shirt on
May 25, 2008. 7:33 PMLinuxH4x0r says:
Not a bad idea. I should make one with a battery and inverter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:liseman
bicycles, gardening, and other important stuff
