Step 3Wire It All Together, Screw Them In
To do this, I cut lengths of wire a few inches longer than the space between outlets, stripped both ends, and interconnected the outlets before fully securing them to the box.
Brass to black, silver to white: to wire your outlets w/ the right polarity, connect the black wire to the brass screws and the white wire to the silver ones. And, if you're more safety-conscious or just plain smarter than me, go ahead and hook up that ground wire as well:)
Your on-off switch should be connected to black (hot) directly from the incoming power cord if you want it to control power to everything.
For any light sockets: wire these such that they won't interrupt your circuit when a lightbulb is not present. One way to do this is to wire in parallel to any of the outlets (your outlets are connected in series to each other).
After I had everything wired together, I secured the whole shebang to the toolbox. For the outlets,
this meant cutting a pilot hole for the included screws and then screwing them through the plastic. On the light sockets, that's layers of electrical tape wrapped until i had a thickness on each side that was enough to keep the socket from sliding into or out of the box.
On the power cord, I tied a knot on the inside and then did the electrical tape trick for the outer.
Add Comment
