3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making A Fridge Compressor Into A Vacuum Pump
I have wanted a vacuum pump for some time, but I refuse to pay the price for a new one that looks of sufficient strength and duty that I imagine I need.
I have read in different forums about the making of a vacuum pump from a fridge compressor, but with the mixed reviews I was reading I was a hesitant. I am glad I finely did. What a nice unit. I have not used it for any applications yet as I just completed the unit yesterday and have been testing it.
________________________________________________________________________
In an attempt to produce more airflow (CFM) I broke this vacuum. I am glad I have started to find these for free. I tried to drill out the discharge to see if I could get more air flow. I have to say don't bother. The line inside is far more restricting and what a pain in the arse to fix, and still have it not work.
The new pump I found is not as good as this one, but should still work for my needs. I will be keeping my eye out for another.
If you are hunting for one look for a compressor with the starting capacitor like this first one. The only real difference between the two compressers I have is that the first had one and the new one does not, and the new one seems to have a hard time starting against the higher pressures.
Step 1Finding a Fridge Compressor
I found mine out back of a local Motel.
The unit is from a small bar fridge that is common in Motel rooms. Someone else had already removed the coil from the back so I could not scavenge that, but the coil and the coolant was gone.
Note: If the coil is still attached to the fridge there is a good chance that there may still be some pressure on the system, so be careful when cutting lines. There was also talk of oil spilling out of compressor, but mine did not spill oil, even when turned upside down.
I snipped the lines, leaving as much as possible, with a heavy set of side cutters I carry in the truck. The wires were cut as long as possible and the starting capacitor was unstrapped and saved.
What I needed besides was:
A power Switch w/face plate
Junction Box
Cord w/plug (junk TV I had)
Tennis ball ( with a few small scraps of rag)
Copper tubing
Vacuum gauge
Plastic tubing
Compressor Oil
Tools:
Soldering torch w/solder
Small pipe cutter
Screw Driver
Hot Glue gun
Large syringe
44 comments
1-40 of 44next »
Nov 8, 2009. 4:27 PMdownunderkid says:
This is a great instructable.
I have managed to find an old deep freezer that still works with coils attached - Was wondering how to remove the coils?
Oct 17, 2011. 5:16 PMzapro says:
You cannot do this. You'll let out the charge of refrigerant, and it's very bad on the Ozone layer. Find a compresser elsewhere... (see my earlier answers further up etc.)
Jul 29, 2009. 8:55 PMyotnomuk says:
i've got a couple ofquestion. im using a fridge compressor to replace the motor on my 1.5 hp 3 gallon craftsman so that the whole setup is quieter, the switch turns on below 90 psi and off at 125 psi. the question is , do i need a starting capacitor for this setup and should i put a check valve on the "out" line so that the pressure in the air tank does not back up to the compressor? thanks
Jun 20, 2011. 5:05 PMSkipper333333 says:
Hi
As far as the capacitor goes the one already on your unit should be fine. And a check valve is always needed to separate the tank from the compressor. Otherwise the pump is too hard to rotate and may not start (trip breakers or stall).
When the compressor gets up to pressure (cut out) and shuts off, the line from the pump to the tank will bleed down its pressure through the pump allowing the pump to start easier.
I used to repair air compressors.
Aug 9, 2011. 12:50 PMuberdum05 says:
Or you can get valves which I think are called something on the lines of an unloading valve which sits between the tank and compressor so that as soon as the compressor stops the tank is sealed and the air line bled. If you ever listen to a compressor that is what the sharp hiss is after the motor stops :)
Jul 31, 2009. 8:08 AMyotnomuk says:
I started this project after watching this videohttp://www.youtube.com/watch?v=QpPpi_Z7ja0&feature=related and it looks very promising. thanks for your help. just have one more question, what kind of oil do i use to replace the compressor oil, are they common in hardware store(home depot/menards)?
Feb 8, 2012. 10:25 PMDeeg says:
Where did you add the oil? Into the air-intake tube?
Feb 9, 2012. 9:26 AMDeeg says:
Nevermind, I'm a dork. I totally missed the maintenance step.
Jan 11, 2011. 3:00 AMzapro says:
You REALLY should not open up a sealed system and let out the refrigerant to the atmosphere. Even R143a is 30 times as harmful as CO2 for the environment, and in some states you will get a BIG fine if it is found out that you let out refrigerant. Just keep this in mind.. I had 3 portable aircon's i'd like to disassemble for the compressors, but as i could not find anyone who was willing to recover the refrigerant i ended up giving them away for their intended use :-/
Jul 26, 2011. 9:08 PMtinstructable says:
Why didn't you just pour it into a sealed container and go from there?
Jul 27, 2011. 12:34 AMzapro says:
As it is a pressurized gas-system, you cannot just "pour" it out. You need to get a piercing valve, clamp that onto on one of the refrigerant lines, then get an empty gas canister, vacuum it out and then connecting a recovery pump between the canister and the appliance you are emptying from refrigerant. (An old refrigerator compressor will do just nicely, too) I do not have the equipment, and nowhere to turn in the refrigerant for reclaiming. Putting refrigerant back into containers not inteded to do so is penalty by fine too, so it's only for the professionals. This is partly because you can suffocate from R134a, since it's heavier that air, and does not smell at all, so you suffocate without even knowing it before it's too late. Another is the environmental issue, which isn't to be overlooked...
Jul 26, 2011. 5:25 AMjoe.grent says:
How about using a water cooler compressor instead for low air volume containers?
May 12, 2011. 11:02 PMgolddigger1559 says:
what kind of compressor was in it?
Sep 19, 2010. 3:05 PMjaaz95 says:
k mine didn't have a wiring diagram on it. so how do i wire it up? it has the two main black coards for main power, then 3 red, white and blue wires that i have no idea what they do. also how strong of a capacitor do you need to start it?
Jun 28, 2010. 1:57 AMgummypaul says:
I made one of these last week to use to pull a vacuum on automotive a/c systems. Works great. I've heard these should not be started under vacuum as it puts a strain on compressor. Don't know if its true but I put a tee on it with a small valve in case I have to turn it off and back on.
Apr 21, 2010. 9:35 AMBobS says:
As I understand, one unit would be able to suck the air out to about 1/30. Putting 2 in series would theoretically result in a vacuum of ca. 1/900 (about 1 mbar).
 Of course there are losses. What could be the pressure achieved?? Would adding a third stage still improve the vacuum?
Feb 10, 2010. 12:07 PMpetercd says:
I have found the small fridge type compressors to be unsuitable for this sort of application, usually  the connecting rod breaks because its only spot welded onto the "big end" bearing.
Internally, the motor rests on rubber grommets, so tipping it over onto its side usually trashes the compressor. ( the reason why fridges are only transported vertically )
However the main problem is that the refrigerant and oil mix which keeps the motor from burning out in its original setting, can no longer fulfill its function once the motor is hacked from the fridge.
Thus its lifespan is very limited.
A much better idea is to use a rotary piston compressor like that used in split system aircons.
These rotary piston types have an accumulator tank to store the oil and don't spray an oil mist over everything, also these pumps include a thermal cutout on top of the motor housing, and a plus factor is that the field coils/motor is welded to the casing, so no tip over problems.
I picked up mine at the scrapyard and it worked fine, I bought some compressor oil ( Reflo 68A ) from a specialist aircon supplier, and its been running sweetly for 4 years now.
Feb 22, 2010. 9:06 PMlukeyj15 says:
with the split system air con, do you use the outside unit, or the inside unit?
Feb 23, 2010. 12:38 AMpetercd says:
its usually the outside unit, with the noisy compressor motor, in it
Feb 8, 2010. 7:43 PMphoton303 says:
You need to have the coolant inside the fridge removed by a professional. Most of the old fridge have coolant that are pretty bad for the ozone layer.
Feb 8, 2010. 12:35 AMdatas_brother says:
Nice job! A couple of tips from my experience:
I use a similar setup for vacuum bagging carbon regularly. To get the bulk of the air out I use a standard shop-vac. Pulls the mass of the air out in seconds.
As a reservoir, I use an old fire extinguisher. By adding two T-valves you can hook up both ends of the compressor to it and switch between pump and vacuum. Put the manometer and vacuumeter on the input of the valve otherwise you will pull a vacuum on the manometer, which will ruin it.
When using as a pump, add a filter to the vacuum side to prevent dust from entering. Dust will kill the pump very fast.
Use a mechanical timer to switch it on and off every 15 minutes. If you pulled a full vacuum and the system is otherwise sealed, this is enough to maintain the vacuum without over-heating.
Cheers
Jan 5, 2010. 11:23 AMmobolised says:
It depends on what refrigerant the compressor is running on, probaly R22 and there for it needs a heavier oil which is a thick and colden but if it is R407 it should run on 3MA oil which is ligher.
Aug 2, 2009. 5:19 AMericlorda says:
Hi! this a nice project did you try to connect the 2 motor in a series connection as i seen on youtube and it becomes a 2stage pump.If you try it what will be the strongest suction the parallel or series connection?
Jul 14, 2009. 4:47 PMbob the builder #1 says:
nice! been needin' a vacum pump
Jun 8, 2009. 10:00 AMFyreAntz says:
Most excellent instructable! Would a set-up like this work for sand-casting? Thanx!
Jun 1, 2009. 9:28 AMBryan Smith says:
I made one for evacuating an R134a air conditioning system. I bought a fitting to go on the freon can from the parts store, cut off the end with a hacksaw , drilled it out to go over the vacuum pipe and soldered it on.
May 14, 2009. 8:42 PMantlion71 says:
What kind of mercury are you drawing on this?
May 9, 2009. 9:21 AMScott_Tx says:
This would be nice for desoldering maybe.
May 7, 2009. 1:25 AMFypsigon says:
...just what I needed! Thanks!!!
May 6, 2009. 9:35 AMkelseymh says:
Very nice! Not everyone on this site is electrically experienced (or competent). If you could, I think it would be very helpful to expand your Step 3 (or add steps between 3 and 4) which include some closeups inside your Handy Box, showing the wiring connections to the switch. You might also consider (for safety :-) using a plastic quad-size Handy Box to enclose the startup cap as well, and then run the power cord out through a grommeted and strain-releived knockout.
May 6, 2009. 11:16 AMLithium Rain says:
Stuff and nonsense, it's not that complicated - the red wire and the black one do exactly the same thing, it doesn't matter if the main is on or not, and people who tell you to check the voltage are just wusses.
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:strmrnnr
