Step 3Putting the Pieces Together.
I installed a piece of 1/4 inch copper tubing over the out pipe and soldered it in place. I then bent the pipe up to a level higher then the top of the compressor and installed the tennis ball.
The tennis ball is slightly modified by puncturing holes and being stuffed with scraps of rags before installation. It works as an oil vapor collector and muffler at the same time. The compressor is very quiet, but with the ball, there is no noise from it at all.
As a note, some people use these compressors as compressors for air brushing with paint. The install a proper oil collector inline and from this they run a line to the air brush for painting.
On the In pipe I just straightened the pipe out so that it ran horizontal and cut the squeezed end off with the pipe cutter.
I have gone a bit cheap on this section right now because it was late at night and the stores were closed, and I can.
I took a piece of 1/4 I.D. plastic and hot glued it to the pipe. It can be easily cut off later if desired, but will be good to run a few tests.
The wiring is pretty straight forward - follow the diagram on the box the switch came in. The wires run into the junction box, attach the wires to the switch, attach the switch to the box, then put on the cover plate.
The starting capacitor it left as is and should not be altered.
As far as the capacitor goes the one already on your unit should be fine. And a check valve is always needed to separate the tank from the compressor. Otherwise the pump is too hard to rotate and may not start (trip breakers or stall).
When the compressor gets up to pressure (cut out) and shuts off, the line from the pump to the tank will bleed down its pressure through the pump allowing the pump to start easier.
I used to repair air compressors.
