Introduction: Making a K'nex Model on MlCad
This instructable will show how to use MlCad efficiently to make a k'nex 3D model and will show you some other useful tricks such as constructing parts that aren't included.
I will be adding more steps over time.
Step 1: Downloading and Entering the Program
1: Click on the link below to download MlCad.
https://www.instructables.com/id/ELCWEISDRBEXCFBLN3/
Click on the link Knex.zip. Save the file.
2: Once you have downloaded MlCad, find the folder labelled Knex. If it is not already on your desktop, run a search of your computer for a folder titled Knex.
3: Enter the Knex folder and double click on the application titled MLCAD.
4: Mlcad is now opened.
Step 2: Building a Y-Connector
1: This is what the final product will look like.
2: To start, go to P in the parts bin.
3: Pull out one Panel 1 x 2 x 1.
4: Copy and paste the panel. Flip it so that it mirrors the other one.
5: Go to T in the parts bin.
6: Pull out one Technic Pin Joiner Round.
7: Add a connector.
8: Use the connector to adjust the distance of the two panels from each other.
9: Delete the connector.
10: Select all 3 parts.
11: Group the parts, and call them Y-Connector.
Step 3: Increasing Rotation Angle
1: Select a part. Go to Edit, Rotate, Keyboard Entry.
2: Check the box next to Use rotation vector values. Type 1 for Z, type 45 for Angle. Hit OK.
3: You should now be able to rotate parts by 45 degree increments in medium grid mode.
Step 4: Essential Hotkeys
These are the most important hotkeys, memorizing these will save hours.
Ctrl-D: Duplicate
Arrow Keys: Move
Ctrl-Arrow Keys: Rotate
Del: Erase
