Introduction: Making a Steady Cam Type Rig for Your HD Vid Capable DSLR
This is my first intructable so I hope you can follow it OK. To start,
The idea for this rig came Scott Eggleston http://filmflap.blogspot.com/
And also from Dave Knop from quick FX https://www.youtube.com/user/Knoptop
You'll need some stuff before you start the actual project
PVC pipe ( a 10 foot piece is more than enough)
PVC pipe cutter or hack saw, OR power miter saw (makes cuts go faster)
Pipe insulation
A 1/4 inch by 20 bolt and a match threaded knob, (I am a woodworker and have a few lying around from assorted jigs and fixtures)
A grey PVC conduit 3 way.
PVC pipe glue
A hand drill and a bit to fit the plug from the Mic. and the bolt
A small microphone ( I got mine from a thrift store for a buck)
And a stuffed animal, A REALLY FLUFFY one. ( Again with the thrift store.)
ALL PVC MENTIONED IS 3/4 inch.
Pipe insulation
PVC pipe glue
Step 1: Cutting the PVC
Couldn't be easier with a PVC cutter or power miter saw (Again, I'm a woodworker)
You'll Need:
One 9 inch
Three 6 inch
Four 4 inch
Five "T" pieces
Three "L" pieces
Three 1.5- 2 inch pieces
and 2 1.25 inch pieces
The grey conduit box, bolt and threaded knob are also shown.
You'll Need:
One 9 inch
Three 6 inch
Four 4 inch
Five "T" pieces
Three "L" pieces
Step 2: Continue Gathering Parts.
You already saw the conduit box, but here's a close up.
Foam (Un slit) insulation for the pipe. Some plastic feet, and a cheap (Or expensive. Mine was cheap) microphone.
A stuffed animal of the really fluffy variety. I WILL NOT TAKE RESPONSIBILITY IF YOU TAKE YOUR KIDS' STUFFED ANIMAL.
(You'll have to cut an appendage off of it.
Step 3: Preparation.
You'll want to do some prep work here before you get to involved.
Drill a hole through the side exit on your conduit so it is somewhat centered, after gluing some foam down on it (if you choose to do that)
Threaded knob and Bolt.
Assembly. Thread bolt through the BACK of the knob. The front piece will fit through the side exit of the conduit and the bolt through the
hole you drilled.
Assembled.
Drill and slot 9 inch piece.
hole you drilled.
Assembled.
Step 4: Wiring.
Pull the wire for your mic through the 9 inch pice slot to mic side adding foam pieces as you go.
Push tight together. (no glue until you're positive it is how you want it.)
Showing the "T" So you can see how the wire is routed.
With foam
Set aside this assembly. AGAIN, DO NOT GLUE YET!
With foam
Step 5: Begin Assembly
Your predrilled side exit conduit piece.
Put one 1.25 inch pice on either end, (you CAN glue this in the conduit.)
Add a "T" to each end. the "front" part (Dictated by whichever side your mic plugs into your camera) will me horizontal.
The "Back" vertical.
Two 4 inch pieces for the front part.
assembled
Two vertical "T" pieces attached to the two 4 inch pieces
Top view of assembled lower carriage. with 2-2.5 inch pieces, (you'll need to check your knobs clearance for this measurement.)
Flip it over and add the "feet"
Flip it back "right side up"
assembled
Step 6: Continue Assembly.
Add the 6 inch uprights. (Foam removed for clarity.) The rear one is actually part of your previous mic wire assembly that's why you can't find it.
Add mic wire assembly (see? told ya)
Pull plug end of mic wire though junction box and push through that hole you may not have drilled yet.
Push it together.
Add foam to uprights.
Add the remainder 4 inch pieces to the T with foam and elbows on either end. (apparently I deleted that picture... Sorry. )
Push it together.
Step 7: Nearing Completion
Attach the mic with hot glue, screws, or red vinyl electrical tape (I'm keeping mine somewhat temporary I may have another idea)
Zoomed out view of the mount job... Snazzy.
Add the stuffed animals appendage sans the internal stuffing.
To avoid making mine permanent I didn't glue it but slid it between the mics base and the PVC "T"
Pulling it over the top of the mic to cover it well. (this will help guard your audio against wind noise.)
Step 8: Attach the Camera
Remember that knob assembly?
It goes through here.
Just like so...
so that approximately .25 inches is sticking out... a little more than that is OK if you used a knob like mine.
it'll look like this from the bottom of the rig.
Now, insert bolt into camera body tripod mount. and tighten with your thumb on the bolts head, when you feel resistance, use the knob only and tighten until it is snug... DO NOT OVER TIGHTEN, YOU WILL DAMAGE YOUR CAMERA AND I AM NOT RESPONSIBLE!!
Just like so...
Step 9: Plug It In
Take the plug wire and plug it into your cameras Mic jack
Now push the extra wire back through the hole in the conduit junction piece (Install cover plate first)
Halfway through.....
Leave a little slack.
Step 10: GO TRY IT OUT ALREADY!!!!
OK.... What are you still doing here??? GO MAKE A MOVIE!
