3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making BioPlastics, Environmentally Friendly Plastics
This is my first instructable so please try not to criticize to harshly.
BioPlastics are plastics that can be made out of common household products.
These are to the environment in that they contain no petroleum unlike usual plastics such as tupperware etc. Also instead of taking about 100 years to fully decompose it only takes about 7.
There are probably other instructables about BioPlastics out there, but I made some for a school project so I decided to make an Instructable
Step 1Ingredients
Ingredients
Here are the ingredients that I used...
-Corn starch
-Water
-vegetable/Canola (Optional)
-Wax Paper (optional)
You will also need a microwave.
And measuring tools
30 comments
Mar 10, 2012. 12:14 PMjbaker22 says:
I made a bio plastic similar but with vinigar and gluconate it stayed a gel. For a day and I through it away. Did I just need to wait longer?
Jun 28, 2009. 3:22 AMGeli12 says:
I Want to make small billiard balls. This plastic is good for that idea? Geli
Nov 11, 2011. 3:07 PMLandon Sullivan says:
I would have to say no. This stuff is pretty soft, and the balls bashing each other would warp them pretty badly before too long.
Sep 12, 2009. 1:49 AMsharlston says:
if it decomposes in 7 year does that mean we cant keep them for more than 7 year?
Nov 11, 2011. 3:06 PMLandon Sullivan says:
Decomp usually only occurs when things are exposed to high levels of unfriendly conditions. Basically, keep it indoors. Should be fine for a while. 7 years is a pretty long time to be used consistently for a lot of plastic products.
Sep 14, 2011. 6:24 PMlyka11 says:
I really need to know if there would be side effects when i add shrimp shells, please do help me.
Sep 14, 2011. 6:23 PMlyka11 says:
Do you think it would come out right if i add shrimp shells in the ingredients?
Sep 14, 2011. 6:22 PMlyka11 says:
Good day. I'm a junior highschool student and in our Research subject, every one should pass his/o r her own proposal. My proposal was using shrimp shells as an additive in making plastics. As i browse through the internet, i noticed that your methods are easy so i decided that i will used them and just add the shrimp shells. Do you think it would still come out right? is my proposal possible? what could be the side effects of adding shrimp shells? Thank you. May you reply quickly for i really need your help.
Aug 29, 2011. 7:00 AMgregstevens says:
Hi! Great instructable.
It might also be worth mentioning that there is an entire website dedicated to providing current news and answering student's questions about making bioplastic. It's at
http://green-plastics.net/
It has recent articles on everything from why certain ingredients matter (e.g. why some recipes call for vinegar and water) to how to get certain types of results (e.g. how to make a hard, water-proof bioplastic in your home). It would be great if you could let your readers know about this resource in your instructable!
Mar 30, 2011. 8:11 PMprometheus442 says:
What do you think about using vinegar? I saw a recipe that uses vinegar to break up the shorter amylopectin polymers, leaving the much longer amylose polymers and making the plastic less brittle. The process is apparently called "acid hydrolysis". He also uses glycerin for a similar purpose.
Here's the video.
By the way, I'm really new to this subject. I only started researching it today.
Jun 1, 2011. 9:33 AMBrandon121233 says:
thanks for the rep
Nov 11, 2010. 3:12 PManarchy burger says:
how flexible is this stuff, exactly? i've seen recipes for producing this stuff on the stove, but there have been so many different results.... depending on the amount of oil added, would this material be appropriate for making something like, say, a mold tray? or does it come nicely out of molds?
Jun 5, 2010. 4:38 PMguitarmonk15 says:
first, This looks AWESOME, also, what would the substitute time be for a convection oven (regular oven) (i don't have a microwave, sad, I know). BTW, how hard is the plastic when cooked (comparisons).
Dec 19, 2009. 10:37 AMJohnJY says:
I put my batch in the microwave,  it turned hard instantly, and I couldn't pour it into my mold, I can get around that, but when I make large batches, It likes to break open, like airs trapped inside, how do I get the air out?
Dec 16, 2009. 4:14 PMebenalart says:
try to add some wood glue that get more strenghth use   to make wings for rc plains
Nov 19, 2009. 4:21 PMgarrett10 says:
Omg, i did this before this instructable was made and it didnt work. thanks for adding oil to the mix. mine was too brittle at first
Aug 14, 2009. 7:28 AMrobokid says:
cool,great,descriptive all you could want in an Instructable! I'm using this to make brackets for a robot . do you think it could hold up 40oz or so?
Apr 21, 2009. 4:44 AMjtobako says:
How do you control shrinkage? Mine always drys at the surface, then the interior opens up like Carlsbad Cavern...
Apr 22, 2009. 3:10 AMjtobako says:
The problem is that the surface drys and sets up while the center is still wet. When the water in the center drys out, it pulls the still soft materiel away from itself, creating a huge hole. What has to be slowed isn't the evaporation rate, it's the setup rate...but then you couldn't use it...
May 15, 2009. 8:09 AMsharlston says:
you could put it in the oven put lower temprature
Apr 28, 2009. 2:42 PMCafeT says:
I don't believe that's correct. The mixture is high in water content, I'm guessing the starches might absorb the microwaves, too, and there's two cups of liquid in the microwave. Outside regions would probably heat up first.
http://www.straightdope.com/columns/read/2118/do-microwave-ovens-cook-from-the-inside-out
Apr 29, 2009. 1:37 AMjtobako says:
The outside still drys first-evaporation is faster than the water can get out, and the steam that forms inside still forms bubbles.
May 14, 2009. 2:37 PMAACRJimbo says:
This sounds really awesome and useful, could you be more descriptive possibly of the end result material? I am making large pieces of a game board and would like to use something like this. The way you described it, they are not very heat resistant? Can they be milled, sanded, shaved, drilled ect after they are dried?
Apr 27, 2009. 8:19 PMBrowncoat says:
Any problem if you added a few drops of food coloring?
Apr 29, 2009. 1:36 AMjtobako says:
Regular food coloring looks very pale, you need the industrial strength ones for cake decorating to get good, dark color.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:nrepak
