Making Charcoal at Home. Free DIY Fuel
6,231
69
4
Posted
Introduction: Making Charcoal at Home. Free DIY Fuel
Charcoal is a main fuel for my metal melting furnace. This time I want to share how I usually make it.
Step 1: Preparing Firewood and Starting a Fire
To make charcoal I use all the wood I have. No matter if it's dry or wet. I load firewood in steel containers, add some gasoline and start a fire.
Step 2: It's Time to Close Containers
After some time time (in my case it was approx 2.5 hours) it was time to close containers. No air should get inside!
Step 3: Got Perfect Charcoal
After 24 hours I opened containers. Only the upper layer of firewood didn't become charcoal. All other firewood became perfect charcoal. This quantity will be enough for 4-5 aluminum (brass, copper) melting in my smelting furnace.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
4 Comments
How much wood do you start with, and how much charcoal do you end up with?
Hi. I should say that this method is very efficient. You lose very small quantity. Because of the container, not a lot of air get inside. There is not enough oxygen to burn underlayer.
Not to sure about the gasoline part, but other then that, it is a good idea.
Thanks. Why are you not sure about gasoline? It's just to ignite wet wood. :) I always add it even with dry wood. It works the same as any other lighting fluid. :)
