3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making Compost Tea
Making Compost Tea
Compost tea is a liquid solution or suspension made by steeping compost in water. It is used as both a fertilizer and in attempts to prevent plant diseases. Compost tea is made by steeping compost in water for a variable period (24-48 hours), then applying the liquid undiluted as a spray to plant parts, or as a soil-drench , such as to seedlings, or as a surface spray to reduce the amount of harmful bacteria and fungi on plants.
Step 1Materials
Materials
There are two parts to the materials. The first group is to brew the tea, and the second set is to filter he tea for actual use.
For Brewing:
1. Compost (I prefer to use organic manure compost, but any kind of compost will do)
2. Five gallon bucket, or any water-tight container
3. Unsulfered Molasses (This acts as food for the bacteria)
4. Air Pump
5. Hose for the air pump
6. Shovel
7. Water
For Filtering and use:
1. Another bucket
2. Wire mesh strainer
3. Cloth for filtering
24 comments
Jul 17, 2009. 6:28 PMDr.Paj says:
So do I heat it before drinking? Or leave it cold?
Jul 22, 2009. 10:38 PMteslafan100 says:
haha funny :P
Apr 5, 2010. 11:22 PMDIY-Guy says:
Our family prefers to brew Llama manure tea. The vegetable plants enjoy a drink of good Llama poo tea. Preferably cold but not iced. (Ha-ha) We got the idea from a site with instructions to brew llama fertilizer liquid at http://LlamaPoo.Com
Almost any animal poop will work, Llama poop might be the best organic fertilizer though.
Filtering and/or settling before decanting manure tea is helpful but adds extra labor. We followed the instructions for manure tea on that other website and found that putting holes in the cap of a plastic milk jug worked well for us. The drilled holes keep the large pieces from floating out of the bottle, and little tiny bits flow through.
Jul 16, 2011. 8:16 PMUQONYX says:
do not use any carnivourous animal or domestic animal's poop because they have microbes in the digestive juices that they use are diseas prone and even if they are vegetarian by nature, usually their food formula also includes some type of meat as Quick Protein
Feb 18, 2011. 10:16 AMPizzapie500 says:
I know this is really late, but where do you get llama poo?
Apr 22, 2011. 7:38 PMjoen says:
Great instructable. But I had a question about whether it would be a way to make nutriants for hydroponic set ups. Can the compost tea be used in hydroponic set ups and if so, how would you work out the strength? Is there a test so you don't over or under nutrient the plants?
That would make hydroponics a lot more intresting.
Thanks,
Feb 13, 2011. 4:54 PMPizzapie500 says:
I have a question: Do you have to filter it? I figure it's only Compost and Water and Molasses so why can't you just pour it onto the base of the plant w/o filtering?
Feb 18, 2011. 10:15 AMPizzapie500 says:
Oh ok THANKS! 5*
Jul 15, 2009. 1:22 PMhollasch says:
Why filter the resulting tea? Wouldn't letting the solids settle out for an hour or so do the trick? After that you could decant the entire bucket, or siphon it. By the way, if you hook up a liquid fertilizer intake to your bucket and spray the diluted result on your lawn once a week, it's supposed to really help it along.
Jul 15, 2009. 1:20 PMhollasch says:
Regarding the water source, if your water source is sterilized with simple chlorine, then you could just leave the water out in a bucket for a day to evaporate the chlorine. Even better, just aerate it with your pump for an hour or so to do the job quicker. Try this first to see if it works for you. If your water contains chloramines, then this won't work. In this case, just go to an aquarium store and get some water conditioner. This should be much cheaper than buying bottled water.
Jul 17, 2009. 12:57 AMpippa5 says:
Hi great looking brew. But is there any way of telling or testing how strong in N.P.K the mix is. And how "strong" or "weak" the liquid fretilizer is. I dont want to burn my plants. Or is it guess work? I would like to make some suitable for tomatoes should I compost more of a certain materials?
Jul 15, 2009. 6:54 PMyoshhash says:
thank you, I'd been looking for an instructible ever since I saw the video with the guy with the gigantic award winning vegetables.
Jul 15, 2009. 12:24 PMSinAmos says:
The funniest part about this is that I was going to do the compost tea instructable, because I recently did one. Just make sure that people know that the bacteria will smell like vomit and poop rolled into one. You really don't need the oxygenator that much. Just a couple stirs per day and sugar. Mainly a feed source.
Jul 15, 2009. 1:15 PMstallionspirit8 says:
drink it! drink it! drink it! haha jk. nice instructable.
Jul 14, 2009. 9:14 PMdchall8 says:
Thank you for adding aeration. I don't go around the Internet looking for bad compost tea setups but they seem to jump out in front of me. Most suggest no air and leaving it for a week to soak. I would suggest not letting it go longer than 24 hours and making it in a cool location. Warm water will not allow any air to dissolve in it, and if you are going to feed molasses to build the microbe population, they will use all the oxygen very quickly - especially in warm water. In San Antonio our tap water is too warm so we would have to make it indoors in an air conditioned space.
Jul 14, 2009. 9:42 AMAndyGadget says:
Great Instructable!
This brew will work wonders for your plants, but to give it a REAL kick, leave some comfrey leaves to rot down in it for a couple of weeks before filtering (but if you do, dilute 20:1 before use as it will be VERY strong). After filtering, don't forget to recycle the solids back onto the compost heap.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:realety
