Making Easy Stencils With the Epilog Laser Engraver
4,371
20
Published
Introduction: Making Easy Stencils With the Epilog Laser Engraver
Cutting out stencils are a pain in the A$$. Here's a way to make stencils quickly using a Laser Engraver. This stencil was made using a laser engraver at my local hackerspace, TechShop. "I made it at TechShop"
things you will need........
1. The graphic for your stencil.
2. Photoshop
3. Vector tracing software (Adobe Illustrator, CorelDraw)
4. Laser engraver
Step 1: Edit Your Image for Stenciling
Try to find you image with high contrast, .png are always prefered over .jpeg  . You also have the option of designing your own image.
Use photoshop to edit any empty free standing spaces creating tabs with the eraser tool. above is a good example on how to stencilize your images. Before and After Light bulb (pay attention to the blank empty spaces).
Use the the outline trace tool in corel draw
http://www.epiloglaser.com/tl_coreltrace.htm
Step 2: Compose and Cut
Using the Epilog Laser engraver is a quick, safe, effective way to cut out stencils.
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
