3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making German Dark Aluminum Powder from Foil
   This is an instructional for manufacturing your own homemade German Dark Al powder. Homemade aluminum powder may not be as good as Eckart aluminum powder; however it is practical for use in pyrotechnics. German Dark Al powder is a particular aluminum powder that has charcoal added to it to prevent oxidation while milling. Not only does charcoal prevent aluminum from oxidizing into aluminum oxide as it mills, it also makes the aluminum powder more reactive bringing about an acceptable product for pyrotechnics. German Dark Al powder is a key ingredient in many pyrotechnic compositions especially in low grade explosive compositions such as flash powder. German Dark Al powder can range from a coarse grade such as 100 mesh to a super fine grade such as 7000 mesh. The finer the grade of the aluminum, the more reactive it is.
Materials:
Aluminum foil
Willow charcoal (1 tablespoon)
Ball mill (or rock tumbler)
Steel media
Measuring tape or ruler
Scissors (or your hands)
Step 1Measuring the Aluminum Foil
First, what you’ll need to do is use your scissors to cut ten 18 inch long pieces of foil.
43 comments
1-40 of 43next »
Sep 30, 2010. 9:21 AMMasterMind555 says:
Will 2 nights will be enough to make an powder fine enough to make a good flash powder or thermite? ( Please, don't judge me! )
Sep 12, 2011. 9:46 PMdlumpkins says:
i do believe it should be around 2:1 in favor of iron oxide for thermite, not sure though.
Sep 16, 2011. 8:05 PMdlumpkins says:
actually, i do believe the "rust" is a mix of oxides and hydroxides. also, i think thermite works best when made with iron(III)oxide(Fe2O3) instead of iron(II)oxide(Fe3O4) both of which are in rust. if i am wrong, someone should correct me.
Jan 24, 2012. 6:49 PMkretzlord says:
old thread, but i'd read in a certain cookbook that baking the rust until i becomes a brighter red will yield a better result.
Jan 26, 2012. 9:53 PMkretzlord says:
yes, it was that book. I was thinking the additional heat would allow the rust to react with some more oxygen. Idk, just a thought
Dec 27, 2011. 12:07 PMziga321 says:
Does the same thing happen when ball milling BP? I know once I ball milled BP for a long time and the container shrinks by quite a bit, althought the container was quite hot to the touch.
Jan 24, 2012. 9:36 PMziga321 says:
Oh, and thanks for answer. So the shrinking was cause when I first ball mill it and it was around that time when I posted this question. The problem didn't repeat though.
The heating was obviously caused by a friction inside a ball mill.
Jan 24, 2012. 9:33 PMziga321 says:
Yes, its because of friction but its the shrinking stuff, I couldn't get it. That was when I first ball mill it, so the problem could be something else..
Jan 27, 2012. 4:55 AMziga321 says:
I never heard of 'rubber barrel' before. I use plastic container, the stuff they sell with (sports) nutrions supplements in. Others I have seen use big plastic (toilet) and alkaten pipes.
Oct 7, 2011. 3:54 PMkrust1 says:
So you can use a rock tumbler too? How would you make do with that setup? I have an old rock tumbler, gasoline powered I think.
Sep 19, 2011. 2:25 AMFreddo789 says:
Hi mate I'm new here , just signed up so I could ask a question so bear with me ! Will it only absorb the oxygen while it is getting milled ? I'm just thinking that I could put my mill on a timer when I leave for work so I wouldn't have anything silly happening while I'm away ? Thanks heaps in advance .
Sep 12, 2011. 9:50 PMdlumpkins says:
hmmm, thanks, this helped allot, right now i am ball milling 325 mesh atomized Al and it isn't getting darker, i had heard of putting charcoal in it before, but that sounded like it would be dyeing the powder rather than making it naturally dark, i will add some to my mix now, as you have explained what it does(stops oxidation). i have been milling for about a month and i decided i was doing something wrong. i will report back soon with my progress, thank again.
Sep 16, 2011. 8:07 PMdlumpkins says:
well with the charcoal mixed in, it is getting darker, and right after mixing, there wasn't a color change so it wasn't dying it. i got it for flash, before i knew which kind to get.
Sep 17, 2011. 1:51 PMSMarshall14 says:
how many hours of milling pure aluminium will be necesary for burning ? (in air or other)
Sep 7, 2011. 2:19 AMlpdunwell says:
if you have an old coffee grinder, this is an awesome way to make aluminium shreds...
Jul 4, 2011. 5:53 AMjsobieralski says:
How vital it it that I check it and let more oxygen at these set intervals(every 5-8 hours)? Because I will have school and I don't want to have to leave the mill off the whole time I'm gone, 5 days a week. If I check it before I leave and again when I get home it will have been running for dead-on 9 hours. I know it's pushing the boundaries a little bit, but would that still be safe?
Also, if, for example, you opened and removed the cap slowly, the flow of oxygen wouldn't be so sudden and abundant, but more steady and controlled. Would this possibly lower the chance of spontaneous ignition?
Jan 25, 2011. 10:25 AMBilldo22 says:
What about the moister from ones breath? could that be enough to ignite it? i had a respirator on that channeled it downward towards what i was working on and i nearly lost my shop just now.
Jan 25, 2011. 8:25 PMBilldo22 says:
it was cold enough outside even with a respirator you could see your breath.
Jan 26, 2011. 12:54 AMBilldo22 says:
when i first took it out at the end of its 7 or 8 days it was really fine and black more than i expected, i did what you said to do thou opened it every 8 hours or so during the first 2 days. i suppose it could have been static discharge that i could have used a anti static wrist strap to prevent.
Jan 27, 2011. 12:26 AMBilldo22 says:
no i didnt. it wasnt that minute it was a good 4 minutes, and that was after i poured it thru a steel screen and onto a piece of paper so i didnt have to run a magnet over it to retrieve the steel balls.
Dec 25, 2010. 8:17 AMrandyclark747 says:
I have tried this, and it took nearly forever to grind it down. I never finished the batch. I think the problem was I couldnt figure what size steel balls to use. I used heavy steel nuts instead, and the result sucked. Does it matter what type steel shot, and size?
Nov 30, 2010. 1:16 PMBerkin says:
Nice work, but your final powder seems a bit chunky. Although, I see it burns quite well anyhow. :D
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:YoungPyro19
I love explosives and the chemistry behind them.
