3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making Hydraulics !!!
 These are the things which are to be needed to built a prototype hydraulics:
1- Syringes (2)
2- Drip case OR pipes of same size as that of cringes nozzle
3- Any liquid (i took water)
4- Glue
Step 1Adjusting them together
adjusting them together
 First take the pipe and check, is a rubber strip as the same size of pipe and that of the head of the syringe , if not then take a small strip of rubber(elastic pic 3) and attach it to the both sides of the pipe. After doing it then connect it with one of the heads of any of two syringes.
Note:- the connection of rubber strip with the pipe and head of the cringe should be very strong.
4 comments
Mar 25, 2010. 1:42 PMjeff-o says:
I used this method in junior high to make mechanical arms and other stuff.  It works well, though the pistons aren't too powerful and they move slowly.  Good to see it finally documented here.
Mar 25, 2010. 3:01 PMlemonie says:
I tried it with Lego pneumatics - much too slow - narrow bore connections.
L
Mar 25, 2010. 3:00 PMlemonie says:
It's years since I played with this sort of thing. I'm sure I managed to weld syringed tip to tip. I like it.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pizzadox747
i am just crazy about electronics!!!!!!!!!!!!!!!!!!!!! BOOM BOOM
