Making Letters Out of PVC (W & R)
Published
Introduction: Making Letters Out of PVC (W & R)
Hello! Today we will be making letters of the alphabet, specifically letters "W" & "R"
The "W" (making the Wonderwoman "W" cuz, yee) will require:
- 5 90 deg. Elbow joints
- 2 45 deg. Elbow joints
- 2 Tee joints
- 6 1in Pipes (or any size that will connect the joints flush to one another)
- 4 5in Pipes
- 2 3.5in Pipes
Step 1: (W) Step One: Supplies
You will need
- 2 Tee joints
- 4 5in Pipes
- 2 3.5in Pipes
Step 2: (W) Step Two: Basing It Up
Using the connecting pieces and the 90 deg. Elbow joints, Make a "W" shape as shown in the image.
Step 3: (W) Step Three: Climbing Up
After your "W" shape is made, you're going to want to throw two 45 deg. Elbow joints to the ends.
Step 4: (W) Step Four: Climb On
Put two five inch pipes on either side to start the signature Wonderwoman "W"
Step 5: (W) Step Five: Step Five
Add tee joints - facing outward - to the top of the five inch pieces.
Step 6: (W) Step Six: Starting to Look a Lot Like Wonderwoman
Add a 90 deg. Elbow Joint to the tops of the tee joints (facing outward) using the connecting pipe.
Step 7: (W) Step Seven: 7
Put the remaining five inch pieces on the top holes to replicate the image.
Step 8: (W) Step Eight: Final Step
Now make put the remaining two 3.5 inch pipes on the bottom tee joint... and you're done.
Step 9: The Wonderwoman "W"
Step 10: (R) Step One: Supplies
For the "R" you will need:
- 5 45 deg. Elbow joints
- 1 tee joint
- 3 1in Pipes (or any pipe that can serve as connecting the joints so they are flush together)
- 1 6in Pipe
- 1 4.5in Pipe
- 1 5in Pipe
- 1 10in Pipe
- 1 13in Pipe
- 1 8.5in Pipe
Step 11: (R) Step Two: Bases
Start by taking two 45 deg. Elbow joints and put them together, then take your 4.5in pipe put it in one of them
Step 12: (R) Step Two
Add the 5in pipe on the side.
Step 13: (R) Step Three
Throw a 90 deg. Elbow on the shorter pipe like so:
Step 14: Step Four
Add the Nine inch pipe on the other side, add two 45deg. joints on the end of the shorter one.
Step 15: Step Five
Put a Tee joint on the side of the 9 inch pipe, followed by a 45 deg. Elbow joint.
Step 16: Step Six
Put the 11in pipe on the side that goes straight down
Step 17: Step Seven
Put the 13in piece on the open 45 deg. Elbow
Step 18: Step Eight
Attach Six inch pipe to back to allow freestanding ability
Step 19: Step Nine (Continuation of Step Eight)
Repeat but for the other side.
Step 20:
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
