Introduction: Making Medicinal All-Salt
Medicinal salt is a combination of sea salt and pharmaceuticals. Medicinal salt can be made by evaporating saltwater that contains pharmaceuticals from urban wastewater. Medicinal salt has not only a great natural salty taste, but can also address headaches, depression, infections, and a host of other common ailments.
It's easy to make your own medicinal salt. The process involves finding a water treatment plant, harvesting its treated water output (effluent), building simple salt evaporation ponds, and collecting the dried sea salt.
What you need:
a local water treatment plant
4 x 5 gallon buckets
wood: two 10ft 2x6"s for the length and two 6ft 2"x6" boards. We made 3 ponds, but one will suffice.
At least 35 square feet of 3mil - 6mil plastic sheet or heavy-duty pond lining (any color, but black will generate the most heat, which is good for evaporation)
staple gun and staples (3/8", 10mm)
1" wood screws
steel corner braces.
black gaffers tape
For more information on the salt we make go to All-Salt.com
What you need:
1" wood screws
black gaffers tape
Step 1: Find a Source
Find out if your local wastewater contains pharmaceuticals. Some information may be found on your local wastewater treatment plant's website, but specific information is generally not, and may only be in the form of reports or studies that your local wastewater treatment plant should be able to point you towards. Call your local plant, and ask if their wastewater contains what professionals and scientists call "pharmaceuticals and personal care product" contaminants (PPCP's): drugs and other industrial, agricultural, and domestic compounds, often classified as "emerging contaminants".
Find out where your local wastewater treatment plant drains its treated wastewater - usually to a nearby stream or reservoir, lake or river, beach, or bay. This information may be on the plant's website, but you may also need to call to ask. You can also uses Google maps' satellite view to see a plant's treatment facilities and grounds in order to locate drainage channels or sloughs coming from the plant.
We found our source in San Jose, CA on the Artesian Slough that comes from the San Jose/Santa Clara Water Pollution Control Plant.
Step 2: Collect Water
Collect water as close to the actual wastewater drainage point as possible. This is where pharmaceutical concentrations will be highest. Often, the immediate drainage points will be fenced off to the public, or only accessible some distance from the plant itself, so just get as close as you can. Coastal water collection is best for making pharmaceutical salts, but not everyone has access to the coast. In this case, freshwater from rivers or lakes can be collected and enriched with any food-grade salt to make saltwater.
- Saltwater Location: Find a place where the 'fresh' water from the wastewater treatment plant mixes with the saltwater into which it deposits (ocean, bay). Harvest water from this location.
- Freshwater Location: Try to gather water from a place with the least amount of suspended sediment or plant matter - just get the freshest water available, closes to the outlet of the wastewater treatment facility.
5 gallon buckets from Home Depot are cheap and good way to contain the water.
Each trip we carried 10 x 5gallon bucks with the help of a dolly. A dolly will save your back!
Step 3: Clean the Water
Clean the water (if needed): depending on where you collect your water (an ocean beach, a freshwater creek, a stagnant pond), your water may contain suspended matter that you do not want to end up in your salt. You can put this water through any filtration process that you are comfortable with, depending on the purity of your source water - you could use something as course as cheese cloth or even a camping pump-filter. Do NOT filter using a reverse-osmosis system, as this process will remove pharmaceutical compounds - carbon filtration systems will not, however.
We used a nylon paint filter that we bought at a hardware store, because it fit nicely over the 5 gallon buckets. Simply fit the filter over the bucket, pour the water through the filter, then remove the filter when the bucket is full. Your water is now ready to pour into your evaporation pond.
Step 4: Make Evaporation Ponds
Make evaporation ponds: You will want to create a saltwater evaporation pond in a flat outside space. For the water collected by two 5-gallon buckets, construct a pond the dimensions of 3'x5'x6". For a pond of these dimensions, you will need the following:
1" wood screws
black gaffers tape
Form the 2"x6" boards into a 10'x6' rectangle, with the boards' 6" side forming the vertical height of the box. screw the ends of the boards together using the metal corner braces.
Spread plastic sheeting over the wooden box, and pulling the plastic somewhat taut (but loose enough so that at least 50% of the plastic rests flat on the ground under the pond), staple the edges of the plastic sheet to the wood frame.
Place a strip of gaffers tape across the plastic sheeting where the sheet will wrap over the top of the wooden frame once you have stapled it to the frame. It helps to first staple the sheeting to the wood near the corners to hold the sheeting in place while you tape and then fully staple it down. The tape reinforces the thin plastic sheeting, and prevents it from tearing when day/night temperature changes cause the plastic sheeting to shrink and expand. Extra plastic sheeting may be trimmed or tucked under the edges of the structure.
1" wood screws
black gaffers tape
Step 5: Pick a Sunny Spot
Place pond in a sunny and flat location. Check make sure you have good sunlight coverage from morning until dusk. In warmer arid climates, evaporation will occur much faster than in wetter, cooler locations - and we recommend you harvest your salt in the summer or when it's unlikely to rain.
Step 6: Fill the Pond
Fill your pond with the water you collected from the water treatment plant, and that you've already filtered (in Step 3). Fill the pond to 1.2-2" deep. On an uneven surface, the water will pool in one section of the pond - this is fine, and will cause salts to condense at this point as the water evaporates.
Step 7: Evaporation
Evaporation: Just wait. Depending on the weather, this could take between 3 to 7 days.
If you have a longer period of time to work with, and especially if you live in a dependably dry and sunny place, you can continue to add saltwater to the pond to create an increasingly saltier brine. This extended evaporation process will result in the making of more salt per pond, and a a greater concentration of pharmaceuticals (more water = more salt + more drugs).
Step 8: Final Step
When your salt water is almost dry - soupy, rather than hard, dry salt, remove saltwater from the pond, and place in a pot to boil off the remaining water (and eliminate any bacteria that may have been present in the water, or accumulated during the evaporation process). When salt is dry, scrape from the bottom on your pot into the container of your choice.
Step 9: Whats in Medicinal Salt?
Every water treatment plant will have different types and amounts of pharmaceuticals, depending on many variables: the size of local cities, whether or not it is an urban or rural location, local populations' consumption of drugs, the method of water treatment used by the plant, and into what type of water the wastewater drains.
Our water source was a freshwater channel composed entirely of treated wastewater that runs directly into a relatively stagnant saltwater. According to the local wastewater treatment plant and a nearby estuary science organization, our salt contained the following:
Primary Active Ingredients:
azithromycin ~ antibiotic
carbamezepine ~ anticonvulsant and mood stabilizer
fluoxitine ~ antidepressant
oflaxacin ~ antibiotic
albuterol ~ bronchodilator
erythromycin-H2O ~ antibiotic
lincomycin ~ antibiotic
sulfamethoxazole ~ antibiotic
caffeine ~ psychoactive stimulant
erythromycin hydrate ~ antibiotic
gemfibrozil ~ cholesterol reduction medication
diltiazem ~ blood pressure medication
trimethoprim ~ antibiotic
May Also Contain:
ibuprofen ~ anti-inflammatory and pain relief medication
naproxen ~ anti-inflammatory and pain relief medication
estrone ~ estrogenic hormone
stigmasterol ~ plant steroid used in the manufacture of syntehtic hormones
tetracycline ~ antibiotic
clarithromycin ~ antibiotic
ranitidine ~ antihistamine
codeine ~ opiate
cotinine ~ alkaloid found in tobacco
cimetidine ~ antihistamine
diphenhydramine ~ antihistimine
metformin ~ anti-diabetic medication
sulfadiazine ~ antibiotic
ciproflaxin ~ antibiotic
~ other trace minerals and chemical compounds including: antibacterial and antifungal compounds from household and personal care products, pesticides and insecticides, PBDEs (flame retardants), and PCBs (electrical coolants).
For further background information and our research you can go to
All-Salt.com/Background
May Also Contain:
codeine ~ opiate
