Step 3Parts You Will Need
IC1 - 556 dual timer IC (24329)
R1, R3 - 1 megohm trimmer pot (42981)
R2 - 1K resistor (661503 or similar)
R4 - 5K trimmer pot (optional volume control--not used in prototype version below) (182829)
C1 - 0.01 uF capacitor (15229 or similar)
C2 - 0.1 uF capacitor (33488 or similar)
C3 - 10 uF capacitor (545617 or similar)
SPKR - 4 or 8 ohm magnetic speaker (673766 or similar)
Miscellaneous: Perforated prototype board (e.g., Jameco 616622), 9-volt battery, battery connector clip (e.g., Jameco 216427), double-sided tape or 9-volt battery holder (105794), wire jumpers (e.g., Jameco JE10 Wire Jumper Kit; 19290).
Note: While the components listed above were used for the prototype, substitutions can be easily made. For example, you can alter the frequencies by increasing or decreasing the values of C1 and C2. Various small 8-ohm speakers can be used.
Prepare the Board and Install the Components
The circuit was assembled on a solderless breadboard and tested. When the circuit was operating properly, the components were transferred to a perforated prototype board (Jameco 616622) and soldered in place.
You can follow your own parts layout (or perhaps one of those shown on the web), and you might consider installing the circuit in a small enclosure. You can also substitute larger pots equipped with knobs so you can quickly alter the stepped tone output. Or you can simply copy the layout I used shown in Fig. 2 to make a trial version of the circuit.
Follow these steps to duplicate the prototype circuit shown in Fig. 2. The jumper leads correspond to the colors of those provided in the Jameco JE10 Wire Jumper Kit.
Be sure to work in a well ventilated room when using lead solder.
comments
Add Comment
osgeld
says:
osgeld
says:
Add Comment
