Making PCB With Heat Toner Transfer Paper and Laminator.
Published
Introduction: Making PCB With Heat Toner Transfer Paper and Laminator.
There are many ways to make PCB.
My favorite method is with Heat Toner Transfer Paper and Laminator.
http://neo-sahara.com/wp/heart_toner_transfer
Step 1:
Cut the copper board and clean the surface.
Step 2:
Print PCB pattern on paper with draft mode.
Put the Heat Toner Transfer Paper on printed draft image and taped.
Then print PCB pattern again with high quality mode.
Step 3:
Cut printed Heat Toner Transfer Paper and put on the copper board and taped.
Put the copper board and Heat Toner Transfer Paper into the laminator about 10 times.
Step 4:
Put off the Heat Toner Transfer Paper.
Check the pin holes and dot on them with marker.
Step 5:
Etched.
Step 6:
  • Clocks Contest
    Clocks Contest
  • Woodworking Contest
    Woodworking Contest
  • Oil Contest
    Oil Contest
3 Comments
I'm currently hacking my laminator and replaced the old electronics with a little controller so I can use it for what it's intended and also for transferring at higher temperatures. So far it seems to work, but I have to watch it for a moment - don't want my house burned down... Hope I can publish an i'ble about that soon.
Hi, ThomasK19.
I think it is very important and is not easy to select good laminator or doing good hacking. I was lucky to find nice laminator.
Your report must be helpful for hobbyists.
Most likely, though I've seen a video from a Russian guy who had a quite primitive laminator with a bi-metal thermo switch that he replaced with a higher rating. Mine has a NTC/thyristor switch which I could rework so I can adjust different temperatures. As said, I have to do a little more testing. But when it's working I'll publish the results and leave a note here.
