Making Rocket Tooling
In this instructable I'll tell you how to make tooling for 1/4 inch diameter black powder bottle rocket tooling.I looked all over the internet for 1/4" rocket tooling, but couldn't find a set. Using things that can most likely be bought from your local hardware store, like aluminum rods, you can make a set for under $25 (excuding the drill and Dremel tool).
Step 1Materials
Materials
You will need-
-Dremel tool
-reinforced cut wheel
-abrasive polish
-polishing wheel
-Drill
-1/4" aluminum rod*
-Tubes that fit the rod
-Ruler
-Vice grips(not required, but handy)
-Sharpie marker
-Some other polish (not required)
-Coarse sandpaper
*Aluminum must be used because that it is completely non-sparking
30 comments
Mar 27, 2009. 2:51 PMI_am_Canadian says:
What do you use this for?
May 22, 2007. 6:56 AMjetnutter says:
never use this tooling for wistle rocket with a hamer you will blow your self up wistle mix fuel must only ever be pressed prefrably with a blast sheild infrunt of your press sorry for being so blunt but its for the safty of the user of this tooling. new member jetnutter
May 23, 2007. 8:42 AMjetnutter says:
I fully agree with you but in the orignail instruck the writer sead it mite be possible to use the tooling for wistle rockets that was the bit i was worried about if used with blackpowder I carnt see a problem. jetnutter
May 19, 2007. 8:29 PMPetervG says:
I'm curious. Could you also just use the dowel you made the case with? It would the the right size, and it won't spark because it's made of wood. I playing around with my case and dowel right now, it could be hammered down and I think would be a perfect ram. I want to hear your thoughts.
May 19, 2007. 8:31 PMPetervG says:
Pictures.
May 19, 2007. 9:01 PMPetervG says:
So I can go ahead and make my bottle rocket? I've made fuses that work very well, and black power from pot nit off of ebay, sulfur from a gardening store, and charcol from a hardware store lol. Maybe it will fly, maybe not. I with I had a smaller dowel though. The BP is annoying to make
May 19, 2007. 9:17 PMPetervG says:
1/2 Homemade Black Match And I'm not sure about the nozzle. Kitty Litter? And I was wondering, when I start to do the ramming, there won't be a hole through it because it will have no spike. Where do I put the fuse then, if there no hole.
May 19, 2007. 9:33 PMPetervG says:
I have a rock tumbler with led weights for fishing. It's quite funny if you see my routine for making black power. It's really stressful to make for me because I'm using all this random stuff. But it works, a bit slow burning though.
Mar 23, 2007. 5:38 AMrhino says:
I need to know where the instructable is that tells me how to use this instructable. Thanks.
Feb 14, 2007. 1:34 PMchuckr44 says:
Non-dairy creamer also ignites nicely when in a fine powder in the air. A few years ago a plant that makes the stuff blew up. Some people were hurt but no one killed.
Feb 14, 2007. 2:01 PMmje says:
Almost anything will burn when finely atomized (unless it's already oxidized). There have been many explosions in flour mills, and mine explosions are typically due to the ignition of clouds of dust.
Feb 12, 2007. 2:57 AMKiteman says:
Aluminium can be used, but it is not completely non-sparking. Powedered aluminium is actually an important rocket fuel.
If you want completely non-sparking, use brass rods or 1/4 inch dowels.
There are some good ideas for mass-producing rocket motors here: http://balloons.space.edu/ndra/nickle.html
Unfortunately, it's very illegal in the UK (a nice man from the local police station carefully explained that I'd be breaking at least three different laws before I even lit them).
Feb 14, 2007. 8:10 AMmje says:
Powdered, flaked or atomized aluminum will burn, but then, so will finely dispersed flour, or atomized brick dust. Aluminum tools are as non-sparking as any other metal sold as non-sparking, like monel, aluminum bronze, etc. Pyrotechnicians have been using aluminum tools for a long time.
Feb 12, 2007. 1:06 PMBiopyro says:
Interesting, did he say which laws?
Feb 14, 2007. 4:06 AMKiteman says:
Health and Safety, explosive manufacture and anti-terrorism were the ones that sprung immediately to mind. It may also break the special laws about making fireworks as well, but he wasn't sure, and he did ask nicely, "please would I not make him have to find out?"
Feb 15, 2007. 3:58 AMBiopyro says:
Ah interesting. many people in the uk do make their own fireworks, and although i think that many do break laws, It's more a police discretion kind of thing. If you're not doing anything to wind anyone up, then the police will leave you to it. If you're causing a promblem they'll take you down. Check out UK rocketry + pyro forums
Feb 12, 2007. 1:29 AMwestfw says:
What's the point in different lengths of rammer if there's no core?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:John Smith
I'm15, I enjoy playing guitar, music, and metalworking. As far as music, I have over a thousand songs of the best music ever(classic rock!). I have a Squier Tele and an Alvarez acoustic. I have a Rola...
more »
