Remove these ads by
Signing UpStep 1Materials
-Dremel tool
-reinforced cut wheel
-abrasive polish
-polishing wheel
-Drill
-1/4" aluminum rod*
-Tubes that fit the rod
-Ruler
-Vice grips(not required, but handy)
-Sharpie marker
-Some other polish (not required)
-Coarse sandpaper
*Aluminum must be used because that it is completely non-sparking
Pyroguide Bottle Rocket
James Yawn's Rocketry website
James Yawn's motor casings
James Yawn's Rocket Motor Page
Haven't made black match yet-I use american visco from skylighter.
Kitty litter or oil absorbing clay stuff works, as long as it is bentonite.Do you have a ball mill? If you do, grind it into a powder, which is pretty much necessary to use it as a nozzle mix.(grinding is quicker if you fill it less than you'd normally fill it)
Use a nozzle drill, and pound in this order:
-stick tape on the bottom of the casing,and pound in a layer of bentonite.
-use a nozzle drill to drill the nozzle
-put the tape on again and pound in the black powder
-pound in the end layer of clay.
Nozzle Drill
This looks like a promising, even burning propellent ,worth testing(w/o the aluminium).
If you want completely non-sparking, use brass rods or 1/4 inch dowels.
There are some good ideas for mass-producing rocket motors here: http://balloons.space.edu/ndra/nickle.html
Unfortunately, it's very illegal in the UK (a nice man from the local police station carefully explained that I'd be breaking at least three different laws before I even lit them).
