3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making Perfect Circles With a Belt Sander
Often, I find myself needing a wheel, plug, or round insert for something and don't have the round stock to make it. Here's the quick way I made a round cap to fit the winch in my small barn using a belt sander.
Step 1Rough-Cut Your Circle
No real need for accuracy here.  Just insure the shape you cut is larger than the diameter of the finished piece you want.
28 comments
Jan 20, 2012. 8:28 AMSteveGerber says:
Why not drive a finish nail through the center into a scrap board and rotate your work piece around and around against the belt sander?
Jan 21, 2012. 8:10 AMSteveGerber says:
Just another thought. You should be able to arrange to make a hole only on one side by driving a finish nail 3/4 of the way through rather than all the way through, then clip the head off, drill a matching hole in your scrap board and pivot.  Actually rather than a nail you could use any stiff piece of wire or round metal (i.e. piece of a bike spoke, etc.).  Just drill an exact sized hole part way through your disc and into the support board.
I made a nice round deck for my Crokinole board by pivoting a piece of plywood through a radial arm saw.   At first you have to keep chopping straight cuts off but once it's almost done you can just spin it through the blade to make it perfect.  This game calls for a large hole in the middle of the board so the pivot point gets cut out anyway.
Jan 22, 2012. 8:24 PMpfred2 says:
You don't have to remove your back board, just use an auxiliary table so you go over it.
Jan 20, 2012. 8:14 AMDr Qui says:
Looks kinda complicated many steps involved. But interesting.
A cheap set of hole saws is a much faster way to get perfect circles, they would have a 6mm hole in the center but are perfectly round, but can be used in a pillar drill with the center drill removed on some sets.
Jan 20, 2012. 8:55 AMkevinn675 says:
thanks for a great instructable. I dont own a lathe nor a drill stand but I do own a belt sander..I can see another instructable coming here...
Jan 20, 2012. 8:31 PMpapagun says:
It would perhaps be faster to drill a hole the size of the "axle" or "center pin" in the "back support" board being used here. Flip the workpiece over and stick the extending "center pin" into the hole. Slowly move that board (with the work or disk attached to it with the "center pin" and free to rotate) towards the running sander until the radius desired is reached and clamp the board in place. Then pivot the work to make a true circle with the "axle" in the center.
I know it is mentioned that the center of the circle is not important in this instructable. Most of the time, the center is very important, however.
I also would not put my fingers into an "enclosed space" this small with the sander I own. Too dangerous.
Jan 20, 2012. 4:07 AMthrobscottle says:
What a great idea - far better than my method of lathe-less circle making! Took me a while to understand step 3 but maybe that's just dyslexia saying hello. Can you devise a method for creating a centre in the piece whilst using this method? (I'm assuming the little peg is just to hold it with) Lefties rule, brother!
Jan 19, 2012. 9:43 PMmruck says:
Guys, you don't get a circle this way. What you get is kind of a "Curve of constant width" or "Reuleaux polygon". Check Wikipedia.
Jan 19, 2012. 9:47 AMdarrellrisley says:
NIce. Although, chucking the plug into a drill and sanding it might have been easier and more controllable.
Jan 19, 2012. 4:35 PMkoebwil says:
It would also give better concentricity, but really a lathe would be the way to go here.
Jan 17, 2012. 1:20 PMpj63 says:
Great Instructable well written and easy to follow..... Oh Thanks for Plugging the Difficulties us 'Lefties' face on an daily basis..... Just Remember 'We Left Handers are Always RIGHT in our MINDS'.... pj
Jan 19, 2012. 2:31 PMtaroblaro says:
No. We Left Handers are the only ones in our Right Minds.
Jan 20, 2012. 10:31 PMpaqrat says:
I believe you failed to mention our humility.
Jan 19, 2012. 7:20 AMwoodmagnet says:
So glad i'm ambidextrous. ;0)
Jan 17, 2012. 2:05 AMSprongll says:
thats really rather nifty, elegant and easy
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:bfk(Children in Freefall)
I'm a lucky man with a beautiful wife and a 3D printer on the way. The best thing is, she wants me to spend my time inventing things for us to use around the house. A true win-win situation. I'm lo...
more »
