Making Simple PVC Flutes
This flute design is a common one on the net, and for good reason. Not only is it simple to build, it's also relatively simple to learn and rewarding to play. It only took a month of on and of playing to be relatively proficient (meaning I could get a clean sound from the first two octaves without difficulty.) The flutes are keyed instruments and only play in one scale (without more complex fingerings) which is actually a plus when just noodling around since you can't easily hit a note outside of the major scale of that flutes key.
My G flute can hit about 2 octaves easily and 2.5 octaves if you push it. My D fife can hit 2 octaves. There are already a number of good sites out there on how to make flutes, but I thought I would add some of my experiences making my own flute collection that haven't been addressed.
For a primer of how to play a PVC flute check out my website: How to Flute
Step 1Design
I used tested designs for my flutes which I found with construction information on Pete Kosel's flute page.
I made a G flute as originally designed and a CPVC D fife to which I also made a modified version. The G flute works great as is, but I was having a lot more trouble playing the fife. It was very difficult to reach into the second octave. Part of the problem I found was to do with the thin walls of the 1/2 inch CPVC. To create for thicker walls with the same pipe, I decided to add a lip plate (like those used on metal flutes) made out of a 1/2 inch CPVC connector.
I also made some original flute designs out of the same material as the G flute but higher pitched in the keys of A and C. These are both easier to play in the bottom octave, but take more coaxing to push into the second octave, especially for the C flute.
To make your own designs or to adapt these designs to different PVC tubing or drill sizes, the flutomat is a handy tool that automatically calculates the hole placement from the tubing specs, drill sizes and key you would like to play in.
57 comments
1-40 of 57next »
Jul 7, 2011. 11:43 AMlesizz says:
I currently play a recorder, so this looks like a nice project for me to expand my skills. I suppose many of the principles described here could be used with other materials such as wood.
There are drill bits made specifically for plastic. They don't grab, and drill through smoothly. I've found that the type with the sharp point leave the smootest hole.
http://www.acrylicbirdcages.com/plastic_working_tools.htm
Jan 4, 2009. 10:59 PMdung0beetle says:
you can make a saxophone too, just omit the embochure and add a 45 degree angle joint and a tenor mouthpiece. (use larger stock for the sax and cut it a bit shorter sounds just like the real thing) I have a bamboo saxophone and it is awesome, just used red hot metal rods to make the holes. Nice instructable! Everyone go grab a saw! There are tons of pipes under the sink!
Feb 24, 2011. 7:22 PMPryo Chain says:
Brilliant! Now... could you perhaps MAKE a mouthpiece, ligature, and reed? From scratch?
Feb 26, 2011. 9:58 PMdung0beetle says:
You could, but it's so cheap to buy them. Unless you plan to make a lot of them, it isn't worth the cost of casting materials.
Jan 7, 2009. 7:14 AMjimstoffel says:
Great Instructable! And thanks for link. @dung0bettle: Do you have notes on how to make the "bamboo saxophone"?
Jan 15, 2009. 11:43 AMetymological says:
I have a friend who makes beautiful self-tuned bamboo flutes with a similar method.
Feb 24, 2011. 7:14 PMPryo Chain says:
Is his name William Miller?
Feb 4, 2011. 9:40 AMsalomon1996 says:
ok, so I made a g flute, and when i try to play it, I get REALY dizzy, any suggestions? thanks!
Feb 6, 2011. 6:34 AMsalomon1996 says:
Thanks, that helps! :D
Nov 28, 2010. 6:42 PMferalin says:
Hi! Is it possible to make a good flute with only a saw, sandpaper, and drills? (and PVC too, obviously!). I do not have any needle files (or ANY files, for that matter). I really want to make a flute like yours, but I do not have a lot of materials!
Apr 29, 2010. 4:52 PMCapt. Kidd says:
its called an embouchure plate. not a lip plate.
Sep 14, 2010. 7:35 PMBodygard1117 says:
it doesn't matter what you call it all that matters is how it works. and calling it the correct name isn't going to make it sound any different.
Jul 17, 2010. 6:57 AMmodhomeecteacher says:
I need a little help in drilling or cutting holes in a section of PVC pipe that I'm going to make into an umbrella stand (to sit next to the front door for umbrellas, not the kind used for outdoor patio umbrellas). I need to cut different sized circles all around for decoration. Is it possible? Do I need to go buy a vice clamp?
Mar 10, 2010. 10:06 PMKryptonite says:
Wow that's awesome, I play flute and would love one of these for school or other places where I can't take my real one.
Dec 26, 2009. 9:07 AMcdousley says:
cool but a cant get sound out of flutes
Dec 27, 2009. 8:05 PMcdousley says:
ty. could i use 3/4 sckedule 40 pipe?
Dec 29, 2009. 1:44 PMcdousley says:
i made a small one out of 1/2 inch pipe today dosent work to well
Dec 25, 2009. 12:47 PMsjoobbani says:
HELP: so from what I understood, the pipe you are using is 1/2 in. I can't manage to find what the length of the flute you are using is, and which one can make the most variation, and best sound. what diameter? what length? where did you drill your holes when you made it? if you would care to give these examples.. that would be greatly appreciated. sjoobbani@gmail.com
Dec 26, 2009. 4:55 PMsjoobbani says:
i'm sorry, this isn't very clear to me, where do you drill the holes.. and how big?
Jul 13, 2009. 4:19 PMRavenShadow519 says:
first off, thanks for this instructable its the single most informative flute making thing i've found! SOmething i've learned from my fiddling around; If you have a bench grinder it works superbly for shaping the wine cork the way you want it. It took was easy to control the removal and left a smooth surface area, give it a try next time your working with it i dont think you'll be disappointed! -Adam
Jan 15, 2009. 7:15 PMgermeten says:
I've played with flutes and recorders infrequently, not enough to be proficient. One problem I've had with flutes is being able to purse my lips, get and maintain the proper angle to the blow-hole, while being finger dexterous with the others. Recorders are better IMHO because the mouthpiece establishes the air angle, leaving one less skill needed to master. So can you advise how to make and add a recorder's mouthpiece to your instructable? thanks.
May 12, 2009. 12:51 PMthepelton says:
I have played a recorder for forty years, myself. I would suggest looking closely at a commercial model, and measuring everything.
Jan 16, 2009. 1:47 PMgermeten says:
Thank you for those other site links, Apart from the instruments, indicate how to make a whistle in a survival situation, easier than I thought.
May 9, 2009. 5:47 PMzac d says:
I t dosnt even work
Apr 22, 2009. 10:48 AMmach2 says:
I have been cutting embo's for sometime. I prefer the oval vrs the round hole for more robust performance. Generally the blow edge and the opposite edge should be equal, in that if you built a straight flute with no embo' offset, a player could play left or right. My ovals generally are the same as the boehm design though this can vary from as little as a millimeter difference in length (8.7x9.7 to as much as 8.5x12mm) The undercut blow edge and sides are not uniform but blend. The angle of the undercut is very difficult to measure because of the curve of the tube but I generally start with a 10 degree blow edge. Some cutters prefer a straight cut and some use a rounded edge. I use a straight edge or "chamfer" and the sides are slightly rounded. Depending on how the 'tuning' process goes I can make adjustments to the embo' by adding more angle on the blow edge. So if you're not sure start with less angle. Just remember you can't add material. Rinse the embo with water before testing. You don't want to breath the dust. I use an exacto knife to rough out, a jewelers file and also some 350 grit paper wrapped around the shank of a drill of near diameter size using double sided tape. I recommend using norton paper as it is also water resistant and finer paper for the finish out. then lighter paper etc.
Apr 7, 2009. 8:41 AMwrightklaw says:
If you play the flute, a boehm system metal flute, perhaps, or maybe your baroque will help you, just look at how the embochure hole is made on those flutes and try to copy it. The whole idea behind it is that the edge of the hole that you blow on splits the air, creating vibrations, so you'll want that edge to be fairly sharp. I hope that helps.
Feb 19, 2009. 7:38 AMsupergokou says:
I'm gonna revisit the embouchure question. I looked at a few websites and I can't seem to get a clear answer on the angle of the hole. If I'm looking at the pipe and the embouchure hole is to my left (this would be the side I would play from), then should I drill such that the drill bit tip is pointing towards me or away from me. You also mentioned "right angle" in your instructions, and I'm not clear if you meant "90 deg" or the "Correct" angle. Should the inside edges of the hole be parallel to each other, or should there be a 45 deg angle on one side and a 90 deg angle on the other side? Thanks for the help
Feb 13, 2009. 10:11 PMRainx says:
Is this in any way toxic to the human body?? I hear PVC is quite dangerous to humans when burned or processed.
Feb 15, 2009. 3:49 PMRainx says:
okay, thank you! Much Appreciated.
Feb 11, 2009. 5:04 PMbakermonitor says:
try using the pipe that has the joints built in to it and using the connection joint for the tuning slide maybe bevel the end of the tuning slide to form a smooth fit
Jan 18, 2009. 3:32 PMLance Mt. says:
4.5 cause, hell it'd be sweet, if i made one.
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:Jnkyrdguy
