My G flute can hit about 2 octaves easily and 2.5 octaves if you push it. My D fife can hit 2 octaves. There are already a number of good sites out there on how to make flutes, but I thought I would add some of my experiences making my own flute collection that haven't been addressed.
For a primer of how to play a PVC flute check out my website: How to Flute
Remove these ads by
Signing UpStep 1Design
I made a G flute as originally designed and a CPVC D fife to which I also made a modified version. The G flute works great as is, but I was having a lot more trouble playing the fife. It was very difficult to reach into the second octave. Part of the problem I found was to do with the thin walls of the 1/2 inch CPVC. To create for thicker walls with the same pipe, I decided to add a lip plate (like those used on metal flutes) made out of a 1/2 inch CPVC connector.
I also made some original flute designs out of the same material as the G flute but higher pitched in the keys of A and C. These are both easier to play in the bottom octave, but take more coaxing to push into the second octave, especially for the C flute.
To make your own designs or to adapt these designs to different PVC tubing or drill sizes, the flutomat is a handy tool that automatically calculates the hole placement from the tubing specs, drill sizes and key you would like to play in.
There are drill bits made specifically for plastic. They don't grab, and drill through smoothly. I've found that the type with the sharp point leave the smootest hole.
http://www.acrylicbirdcages.com/plastic_working_tools.htm
Breathing to play a wind instrument is not very intuitive in the beginning. Focus on where and how deep your breaths are and it will start to feel more natural in no time. And take it slow sticking to short playing sessions while you build up your stamina. It's a lot more work than you would think breathing in and out could be!
The G flute he describes is definitely my favorite. It can easily play 2 full octaves and sounds strong throughout that range.
And this site shows how to make a simple PVC clarinet: The $5.00 Clarinet.
