Step 6Tuning Slide
PVC Connectors
The easier method uses the 1/2 inch connectors already available for the pipes. To add one of these, it only requires that you use two sections of tubing for the flute. One section of the flute, the head joint, has the embouchure; the other has the finger holes. The only tricky part of this design is getting the head joint the right length so it is within range of the correct pitch, when near the center of travel in the connector. This can be difficult due to the small range over which the tuning slide can move.
Acetone
Although more time consuming, the acetone method can make for a better tuning slide since it can be as long as needed. The acetone softens the PVC so it can be stretched to fit on another piece of PVC. To start this method you will need acetone, which is sold as a solvent in the paint section of home centers. You also need a container that won't degrade sitting with acetone in it for a few days. Glass works well for this. The container should be as tall and narrow as possible so as to not waste acetone (once the acetone is used once, it is best that you dispose of it properly or store it separately rather than put it back into the original acetone container since it probably leaches all sorts of unknown chemicals from the PVC.)
To make the slide, I started with enough acetone in my container to submerge as much of the PVC as I wanted to stretch. The PVC sat for at least 24 hours before it was soft enough. At this point I took out the acetone soaked pipe and stretched it over another piece of pipe. I let the pipe dry in this position for another 24 plus hours before it was solid again at which point you can finish the flute as usual. You can stretch either the head joint or the body but it would be best to do this labor intensive process to which ever part you plan on sharing the most between other complimentary sections.
Add Comment
