Making Smart-home Devices
Introduction: Making Smart-home Devices
The idea of this project is to detect whenever a person leaves a room empty and if the fans or lights are on then he will get a ping on his smartphone through an app . Also, the lights and fans can be switched off by using the app itself rather than going back inside the room. It is basically a step toward saving electricity and our hard earned money.
This is a project on IoT(Internet of Things) .A prototype of the above-mentioned idea has been explained here. In it motor is used instead of a fan and LDR(Light Dependent Resistor) is used to detect light
Step 1: Requirements and Prerequisite
1)bolt 2)vibrational sensors 3)motors 4)motor drivers 5)wires 6)breadboard 7)android mobile 8)relay
prerequisite: 1)javascript 2)html
Step 2: Connecting to Bolt
here we are usin bolt as interface with vibration sensor
bolt is an IOT interface, reason using bolt it is easy to use and we can make anything by just using js, html,css
to setup the bolt:
1)set up the bolt hotspot
2)find it using advance ip scanner
3)goto boltipaddress/developers to upload ur file to make it work on bolt
Step 3: To Connect to the Vibration Sensor
1)connect gnd of bolt to gnd of sensor
2)connect vcc ob sensor to 5v od bolt
3)connect output pin of sensor to 0 of bolt
Step 4: The Mobile App That Controls the Fan
Sensor data
The motor on , stop and reverse button are to control the motor and start data and stop data are to start the sensors to sense whether the fan is on or not
Step 5: Ifttt Used to Connect My Fan to My Mobile
1)create an account
2)in the statement "if this then that"......this=maker , and that = gmail
3)then create the recipe
4)goto chose triger then create trigger
5)then write the html code given
6)then submit and upload in bolt
Step 6: The Code
Step 7: Relay Connection Informations
COM-common connection
NO-normally open
Step 8: Light Controling Circuit
  • connections
1)the pin 7 in bolt to in1 in relay circuit
2)5V to vccof relay module
3)gnd of bolt to gnd of relay module
  • we are using NO in relay,so that it can trigger on and off the light
  • Hot line from supply is connected to COM
  • Supply line to AC is connected to NO.
  • Gnd in light is connected directly.
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    Need help in one concept can u please share ur email
    you can ask me on private msg in instructable
    thanks :D ....hope to improve it further
