Ferment Yourself Some Food!: Making Sourgough Starter by joincoolkidclub
Featured
Do you like sourdough bread?
Do you like fermenting sweet stuff and watching it bubble?
Do you want to be able to make your own bread and become less reliant on destructive food making techniques used by large scale producers?
Then hopefully I will be able to show you how to make your own sourdough starter.
There are families that still pass down starters created over a 150 years ago! Your starter may end up a generational legacy past down over the generations!....... but probably not. At least you can enjoy it for as many years as you recondition and feed the sweet, sweet sludge.
***Disclaimer: This is my first experience making it myself and hope that the experiment is successful, so that I reap the benefits of tasty bread and also am able to teach others. This is also my first instructable so let me know of anything I can do to improve it. Thanks!***
I learned how to make sourdough starter from a zine called Wild Fermentation: A Do-It-Yourself Guide to Cultural Manipulation. One of my favorite zines (and zine names) available from:
Sandor Ellix Katz
247 Santuary Lane
Liberty, TN 37095
sandorkraut@heartoftn.net
Also, if you live in the greater Portland, OR area Multnomah County library has a few in the periodical section.
Almost all of my knowledge comes from this great zine.
P.P.S.- Mark_In_Hollywood showed me a great article he wrote about making sourdough starter and reconditioning. Its an interesting and informative read- check it out!
Step 1: Mixing the ingredients...
Ingredients:
-quart size jar (or larger, I used a reclaimed spaghetti sauce jar)
-4 tablespoons of honey or molasses (I used honey because I already had some)
-1 cup flour
Fill the jar with 2 cups of warm water.
Add the honey/molasses and flour and stir vigorously.
Cover the jar with cheesecloth or another porous material (old fabric is free and omnipresent).
dbecker215 says: Nov 23, 2012. 8:21 AM
Using organic flour helps a lot because there is still active yeast in the grain as well. If you use grapes as food look for ones that have a "cloudy" look around the skins as that usually contains yeast as well (that was where the yeast used to make wine came from in the old days)
MichiganBelle says: Jun 3, 2011. 10:03 AM
I must ask this for the good of the bread: What if I have no honey nor molasses but natural good and sweet maple syrup. : ]] I shall try this now... and see what the beings that are give to me. Let's hope for yeast!
Chanio says: Jul 8, 2012. 6:04 PM
By experience, I would deduce that there are things that help in the process of becoming a good sourdough:
* The amount of water and flour should make a sort of chocolate thickness, but not more.
* Anything that sweetens the mixture would encourage the process of fermentation. Then, if the mixture senses a sour taste, it would stop working.
You could add, even a smashed banana.
* Being in the fridge would also slow down the process.
* I am aware that some people succeed earlier because they didn't notice that the flour that they are using, already contain some sort of yeast.
* Adding some baking powder would also make some bubbles because of the nature of the chemical product.
* Making sourdough without the help of yeasts or other products would achieve a better tasting bread. There are people that are making bread by replacing most of the flour with sourdough...
Don't discourage.
If you want to keep a little of a successful sourdough for another occasion, just keep on adding flour without water until all is dry. Then keep it in the fridge with a lid, all the time you want,
Shadeburst says: Jun 22, 2012. 3:38 AM
Because I'm a man and look for the easy no-nonsense way to do it, I also use a jar but with the lid. Every day instead of stirring I just give the jar a good shake. (James Bond was right.) Taking off the lid for ten seconds allows enough oxygen in to keep the fermentation going.
Also I use commercial yeast. As well as the supermarket kind, I get different varieties at the local brew shop. Wild yeasts I stay well away from because they usually end up spoiling the fermentation.
Smokestack Lightning says: Jun 12, 2012. 1:08 AM
Listen to Dr. John is a required step.
biffabacon says: Sep 24, 2011. 1:39 AM
I have made the sourdough stater without adding honey or molasses!
Just mix 1 cup of warm water with 1 cup bread flour, stir and leave in covered jar in a warm place.
Each day I discard about 1 cup of this mixture and replace with half a cup each of the flour and warm water. This seems to get it going well, and the beast is alive and kicking after 4-5 days depending on temperature!
Wholemeal or rye flour works the quickest but I prefer to use the white flour, though you could use half and half.
nerdfighter73 says: May 20, 2011. 1:26 PM
Great instructable! The only thing I would change is your title. It says sourGough and I'm sure you meant sourDough.
Baritone Blues says: May 6, 2011. 11:23 PM
Thank you for the wonderful instructable! Breaks it down nice and easy, and doesn't assume that you know everything. A very good layman's instructable! :)
I have two starters going. One that follows this recipe, and a half sized one.
When they settle, the water is very yellow, not the lovely amber color as you depict. Is this ok?
The smell is very sour, and I cannot wait. Just concerned about the color.
arodríguez3 says: Apr 6, 2011. 5:05 PM
So, say I have a bit of molasses and a bit of honey. Would that work, or is it essentially one or the other?
tabbique says: Dec 8, 2009. 6:17 PM
not to be dense here, but what happens now?  How do I use this to make bread?
ppol says: May 7, 2010. 10:46 PM
http://www.instructables.com/id/Sourdough-Bread/
Foaly7 says: Jan 23, 2010. 2:48 PM
I just tried making this, but I don't know if I did it right. When I made mine, the jar was almost full. Is it supposed to be?
kalunodragon says: Oct 24, 2009. 1:59 PM
 You can actually feed the yeast both some sugar and some flour. For sour dough you don't want the sugar because it wont be a great sour dough then. I am attending a school to become a Baking and Pastry chef. This was actually a question that I had. Since I see that you are asking the same question I feel that I had to answer. There are actually a few other things you can use to start this starter one that is a lot harder to make but give the bread a really unique taste would be apple cider instead of honey. The only difference is you have to use about a 1/4th of the amount of yeast they used in this instruct-able at the start. The reason for this is because of the fact that your using an ingredient that has the ability to spoil so you just want to watch it. If you choose not to use the yeast you might want to put you starter in a cooler place like a fridge for the night then take it out in the morning and stir it. Leave it out for about 6 hours then you place it back in the fridge for about 3. Then do it again. Thats at least what we have been doing in school or learning in school. I hope this helps. And the apple cider sour dough bread tastes great it is a very good bread to complement a thanksgiving day feast or any other feast that you might have with bird. I haven't tried it with other meat but if someone does please let me know.
squirrelist says: Oct 24, 2009. 1:05 PM
I've heard that honey will slow down the process since it has antibiotic properties. There is nothing innately wrong with sugar, we just eat too many simple carbohydrates.
Tararp says: Sep 7, 2009. 6:11 AM
humm... i thought yeast only feeds on sugars..
squirrelist says: Oct 24, 2009. 12:56 PM
Carbohydrates, I think. Sugars are more quickly digested, but once you have a healthy culture going flour will be enough.
canida says: Jun 7, 2008. 6:25 AM
That's awesome! Let us know how long it takes you to catch some wild yeast.
devils darning needle says: Aug 13, 2009. 9:08 AM
Actually catching wild yeast isn't as hard as it sounds. The white powder found on the skins of grapes can be used as homemade starter yeast for bread. There - buy grapes(red are best) - one trip to the market - wild yeast - caught!!!
Mark_in_Hollywood says: Jul 25, 2009. 9:56 AM
To everyone with starter that they thought smelled bad. It's too bad if you threw that in the dust/trash bin. It make excellent bread. For me the stinkier, the better. When starter is "winey" smelling the bread never gets enough sour flavor. If you want more info, have a look at my food 'blog:
Danger! Men Cooking
Nerdz says: Jul 24, 2009. 1:29 PM
what did yours smell like? Mine smelled like stinky feet or like a sweaty gym sock..yuck! I threw it out, I didnt want bread that tasted like a gym sock
crazypiro911 says: Apr 14, 2009. 6:06 PM
mine smells disgusting, nothing like store bought yeast, is this OK
shilohjim says: Jun 11, 2008. 11:59 PM
I'd like to recommend this site for some good sourdough info.
http://www.sourdoughhome.com/
joincoolkidclub (author) says: Jun 12, 2008. 11:45 AM
That website is a great resource. This project, however, centers around making your own starter where as the site discourages doing so.
bddbbd.b says: Jun 9, 2008. 11:04 AM
Good luck! I am rooting for you. The last time I tried this was a long ways back, and it didn't go as well as I had hoped. You've inspired me to try again.
Mark_in_Hollywood says: Jun 7, 2008. 9:34 AM
I have a more scientific explanation of the sourdough process at:
http://dangermencooking.blogspot.com/2004_10_01_archive.html
joincoolkidclub (author) says: Jun 7, 2008. 10:52 AM
Thanks for showing me this- its a very interesting article. I was going for a much more basic approach but now know more of the science behind the process. See the link at the bottom of the intro. NICK
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
