First of all, I would like to thank all of those who visit our forum and help others with advice and offer their great tips and tricks. There have been two alternative ideas posted in regards to creating the hub flanges that I use on trikes and quads such as the DeltaWolf, Kyoto Cruiser, Street Fighter, Gladiator, and Lode Runner. One alternative to the machined disc is to cut the required flatbar or plate using the appropriate sized hole saw. The other alternative is to source out precision made washers of the appropriate size. Often these washers are called "fender washers", "dock washers", or "aircraft washers".
I would like to present another alternative to the machined discs that only requires the use of an angle grinder, and hand drill. This procedure takes about 2 hours for all four discs, and is very effective if you don't mind spending a little quality time with your angle grinder. Since the hub flanges required in the plans vary in size, I will not be posting measurements here, but the same procedure will work on all trikes that use the hub-axle system I have developed.
To see some of the trike and quadcycle projects that these hubs are used on, please visit
http://www.atomiczombie.com .
The flatbar needs to be at least as wide as the discs you plan to make, and the required thickness. This flatbar is very easy to acquire, and can often be found in the welding isle in many hardware stores. You will need enough material for 4 discs, which is the number of discs needed for a delta trike or quad. In Photo 1, I have traced two of the discs using a paper template that was made in Photoshop and then cut out. The traced circles are the same diameter of the flanges on the hub in Photo 1 because I am using the rim and spokes from a complete wheel that had this hub.
The center of the disc must be marked and punched before any cutting, as you do not want to loose this center position. The punched center will later be drilled for the axles. Also, use a marker that can hold up to a little abuse as you will be grinding and handling the discs with gloves.
Very nice and brilliant job!
But I have some questions about it,
I think it's a bit complicated because,don't you think it was easier to take 2 wheels and weld them together with an axe ?
I thought about it but i never tried then I think it might exist a problem I can't imagine.
And the other question is : How did you put the gear on the axe ?
Because i'm really intersting about making a tricycle but I don't know how to make the rear transmission.
Thanks a lot and congratulations again for your job'
I mean, Its a great work, and I'm new on this Trikes on Quadcycle matters.
And I dont know, This long bar is welded to hub and then this same flange is welded to the other hub, Or What did you connect both to the frame??.
Thanks
Mike
I mean, I make my own spokes, I buy the Stainless rods, and I made the threading with a threading die. And I make bend the other side, for put on the Hub.
But I like the way the commercial spokes looks, the circular shape of that spokes ends is beautiful.
Or exist a machine similar to the Spoke Theading machine?
Thanks
