3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making Trike and Quadcycle Hub Flanges Without a Lathe
Step 14Drill the Spoke Holes - Tip
The flanges are bolted to a piece of lumber which is then bolted to the side of my workbench as shown in Photo 14 so that the drill can be held horizontally rather then trying to push down on it.
This position is much easier as you can just lean into the drill rather than needing to put constant downward pressure on it. Remember, that drill bit is not very strong, so only a little pressure is used to avoid snapping the bit. I only broke 1 bit during this build!
2 comments
Jan 23, 2009. 9:18 AMjeff-o says:
Here's where a drill press would definitely come in handy. Kudos for doing it with a hand drill!
Jan 26, 2009. 7:39 PMJamesRPatrick says:
You could try a drill bit wrapped in duct tape. Or just a metal spoon.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
89
Author:KoolKat
