Making a 120V LED C7 Bulb
42,962
51
31
Posted
Introduction: Making a 120V LED C7 Bulb
I wanted a blue LED light bulb for our water dispenser. So I decided to make one.
You need...
3 blue or white LEDs
1 100K 1/2W resistor
1 1N4004 Diode
1 dead (or not) C7 socket light bulb
3 inch of 1/2 " shrink tube
some hot glue
Soldering Iron
Pliers
Paper tube (paper towel or toilet paper tube)
vice
Step 1: The Circuit
The circuit is composed of a 1N4004 diode, a 100K 1/2W resistor and 3 blue LEDs
Step 2: Brake a C7 Bulb But Don't Brake It!
I used a standard C7 type bulb because this is what fits inside the water dispenser.
This will be our base to attach the circuit
You need to brake the bulb, but, you must NOT brake the inside. To do this I inserted the bulb inside a used paper towel tube. and then squeezed the bulb using a vise. When the bulb is broken, it is possible to remove and brake away the rest of the glass, leaving the inside untouched.
Once you have the inside you can remove the tungsten filament, keeping the two leads.
Step 3: Preparing the LEDs
In order to make the 3 LED in a perfect circle, I used a pen and taped them up together in a circle.
Make sure you have the long and short leads all in the same direction.
Solder the first long lead to the next short lead, and so on. Leaving you at the end with one long and one short lead not soldered. These two leads will be the negative and positive of the LEDs series.
Step 4: 3 Blue LED in Series
This is the LED element
Step 5: Solder the Resistor and the Diode to the Two Bulb Wires
Solder the resistor and the Diode to the two bulb wires.
One wire has the 100K 1/2W resistor.
The other wire has the 1N4001 diode.
Take note of the diode polarity, the output of the diode will have to go to the short lead of the LED module made before.
The resistor will go on the long lead of the LED module.
Step 6: Tape the Components
Tape the components to keep them in place and to isolate the 120V from each other and the rest of the components.
Step 7: Install the LED Module
install the LED module.
Slide it on and solder the diode and the resistor to the long and short leads.
The Diode + should be on the short lead of the LED.
The resistor should be on the long lead of the LED.
Step 8: Add the Head Shrink and Glue
Add the heat shrink tube over the circuit,
leave a bit other the metal socket and shrink it a bit so it make a seal. DO not shrink the hole tube.
Only over the socket.
Fill the tube with hot glue. let it cool down in a refrigerator for 15 minutes. This will make sure the glue is cold. This will give you a chance to heat the shrink tube at the and without melting the glue too much.
Step 9: This Is It
Final product. You can bend the LED to the side a bit then add more hot glue to isolate
Screw this in the socket and there you have it a C7 120V blue LED light.
And yes you can add more LED in series and parallel
You will have to recalculate the resistor
You might think this is a long process for nothing. You are right! you can actually buy C7 120V LED bulb already made... But mine was made with stuff I already had around and it was fun to make...
Step 10: View From the Inside the Dispenser
This is the installation. The new LED bulb fits right in where the old lamp was.
Step 11: Second Shop Without the Flash
you can see the LED is directed to the tab you push to get the water... It's a discrete light that will not light up half the kitchen like the old one...
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    31 Comments
    Doesn't the resistor get really hot having to drop the voltage so much?
    Blue LEDs have a forward drop voltage of about 3.3 volts. Since we have 3 in series, plus a 0.7 Volt drop on the diode, we have 10.7 volts drop on all of them. 109.3V remains, to be lost in the resistor.
    The total power in the resistor will be : V²/R = (109.3)² / 100000 = 0.119 W. Since the resistor can take 0.5 W, the heat should not be a problem, but nothing stops you from using a bigger resistor if you want.
    This may be a dumb question, but I'm an amature when it comes to circuitry. You are talking about running this bulb on 120v AC 15-20A, like out of a standard U.S. wall socket right? I checked on what a C7 bulb is for and it was saying AC and a C7 is one of the big old Christmas lights. Sorry if this is a dumb question but i thought you had to have a bridge rectifier and a couple of caps to make LEDs work with AC after power correction (or b4). Like I said, I'm new to circuitry, so bear with me please.
    The voltage is the potential and the amps is the actual flow of electrons. By putting the resistor in you cut down the amps, and because it is a light emiting DIODE, if you put reverse voltage to it (alternating) it will block it (for the most part) and not light up. What you are actually seeing is it flashing at 60 times a second. Otherwise, yes, you would need a rectifier and caps. Sorry for the spelling, my "check spelling" button is having problems.
    ok, so if i wanted to brighten them up a bit, i would have to use a cap to smooth out the signal right? what farad value should i use? (for that matter how does one choose a cap value for any application?) i've got 3 super-bright white leds in series and they're not that bright at all. not to mention that they are pretty directional and i end up with 3 circles on the lampshade. i was gonna use some lighting gel diffusers to try and spread the light out, but it still looks dimmer than they should be.
    No, you would use a lower resistance. Be careful if you go too low you will burn out your LEDs sooner than they should. The caps would be to filter out AC noise from the line. You could try putting the LEDs in parellel instead of series.
    If you put the LEDs in parallel one will tend to draw more current and dim the others. Parallel ensures that they all get the same current. Just lower the resistor if you want more current.
    You don't need a rectifier to make them brighter, just more current. In another post I calculated under 2mA driving the LEDs, so there is a lot of room for higher current and thus brightness. They're being pulsed so you can drive them higher than their DC current rating.
    Why do you what to use a cap for? I have no caps and the light is not flashing. LED are diodes, BUT they don't have a very high reverse voltage, this is why the diode is there on the AC. The resistor is for limiting the current. Each blue LED drops about 3V. So the rest of the voltage will be at the resistor and diode...The circuit works, it does not heat, and there is no flicker. This is a K.I.S. circuit... There is no reverse current to the LED because of the diode 1N4001 and the current is fairly low and not stressing the LED. This is going to last a long time. Plus it's so compact, I was able to make it fit within the size of the original bulb.
    Kind of an old comment, but If you are only using one diode its a half wave rectifier and therefore only flashes at 30 times a second. If you were to use a bridge rectifier, then it would be 60 times a seconds or hertz.
