How-to Forge a Skull Crushing Robotic Arm to do Your Dirty Work.
 by FlyingToaster
I recently was given 10 servos as a birthday present, so the question really was what to do with all of them? I started looking around at robotic websites that offered robotic arm kits. One of the sites Lynxmotion.com sells robotic arms that are very cool, but they are also very expensive at prices upwards of $300. Then I came across a miracle on Lynxmotion's website, an older robotic arm known as the L6AC-KT. The whole construction was of lexan, so I thought to myself, hey, I have lexan as a resource. Now that the build is completed I hope to spread my ideas and hopefully inspire someone to build something equvilent.
Also, if you could please vote for this instructalbe in the Microcontroller contest , the Toy contest , and the Make it Move contest it would be highly appreciated ;D
Step 1: Design and Fab
For this project I used the lynxmotion arm as a large point of reference, but because the site does not actually give any CAD files or any dimensions of the older arm I was forced to make those decisions for myself. I used SolidWorks for the design of the whole arm assembly, this made everything go by so smooth since I could save the files as .STL or .Dxf and have a laser-cutter and FDM machine make the parts for me. Besides that the Items I used are:
1x 24x24 sheet of neon green lexan.
5x Hitec HS-422 servos
2x Hitec HS-645MG servos
1x box of 4-20 x 3/8 self tapping screws
1x box of 2-28 x 1/4 self tapping screws
some 8/32 x 1/4 socket cap screws
Check the next step to see what all the parts are used for...
marvin T says: Dec 10, 2012. 2:53 AM
Hi, i'm about to start this project but might there be any chance of sharing the drawings/codes? I have solidworks so no issues there,
if so please send to marvin@protospace.nl
alessandro290 says: Aug 23, 2012. 7:44 AM
hello can help me , i am searching about this design to save my time i have my final project so plz if can send to me as DXF file , my email is ahmadkhalil2004@hotmail.com
tinker234 says: Feb 19, 2012. 8:35 PM
wow could i make this out of alliaum never can speel that sorry
dchakraborty says: Mar 11, 2012. 6:33 PM
Very nice model.........have you used encoders?? Yes or or no, in both cases please make a tutorial on how to choose, use and connect encoders.
FlyingToaster (author) in reply to dchakrabortyJul 27, 2012. 4:49 PM
Because servos have potentiometers already attached to the output gear, there is no need to use encoders; in fact, encoders would be much more inaccurate. Check this link out for more on how servos work: http://www.servocity.com/html/how_do_servos_work_.html
docdavies says: Jul 27, 2012. 1:29 PM
Any chance you would share your CAD files?
mahsa arian says: Dec 28, 2011. 12:11 AM
cool
thx FlyingToaster
jcano yribarren says: Nov 20, 2011. 1:49 PM
Pretty cool! This neon green material looks great.
I want to make a robotic arm to play chess, but I don't know what to choose, stepper motor or servo. Stepper motors are more precise, but more expensive, heavier and i would need more mechanisms.
So my question is: do you think your robotic arm has precision enough to position pieces in a chess board?
Thanks and sorry for bad english.
FlyingToaster (author) in reply to jcano yribarrenNov 20, 2011. 4:25 PM
The issue I had with stepper motors was with the control, you see I used an 8-bit arduino chip to control my arm, in order to control stepper motors I would need to make or buy an array of transistors, neither option was cheap. I would say servos could easily place chess pieces on a game board, plus you can easily program them to the degree. If you do take the servo route you may need to have stronger servos like the Hitec HS-645 series to have it move smoothly and precisely.
jcano yribarren in reply to FlyingToasterNov 21, 2011. 3:48 AM
Ok. Thank you so much. I will try to create one with servos.
jwkooi says: Jun 21, 2011. 3:48 AM
Nice design. A video would be nice. I wonder: is it smart to have to servo's at the base in parallel? Are you sure they will move in the exact same way. Otherwise it will be a current drain, I gues, since the 2 servo's will try to rotate all the time.
But again: nice job
jwkooi
FlyingToaster (author) in reply to jwkooiJun 21, 2011. 7:15 AM
Good question(s). You are right, they the two servos at the base are going to try to fight eachother, but it can easily be fixed. First you can slot the holes where the lexan is attached to the servo, and second you can always take a servo horn off and reposition it. Both those methods should prevent the servos from fighting eachother for home position.
jwkooi in reply to FlyingToasterJun 21, 2011. 2:41 PM
OK. Slot the hole will work but then only one servo will do all the work or you get a sluggy respons.
One servo will work, but you only have the strength of one.
Reposition the horn: I am curious if it works and keeps working over time.
Maybe it isn't that critical. Keep us posted wtih your experience.
FlyingToaster (author) in reply to jwkooiJun 21, 2011. 4:25 PM
Sorry, what I mean is you can either slot the hole in the lexan the same diameter as the original hole inorder to secure the lexan to the horn. You should not see less performance from slotting the holes because they will still keep the screws thight to the lexan. The second option was moving the horn. Lynxmotion has their lexan slotted, but I think I may set both servos to 90° and adjust the horns to match. Hope that helps. I'll Include more info in the instructable when I have some time.
jwkooi in reply to FlyingToasterJun 21, 2011. 11:48 PM
OK. Seems like you know what your doing. Looking forward to see more results. I have made several project but no robots yet. Would like to but other family thing keep getting more priority. But have a look at the wooden aperture. I made a instructables for that, inspired (read:copied :-) by the cardboard aperture. Keep up the good work.
sarveshk in reply to jwkooiSep 28, 2011. 9:26 AM
I think you can use Futaba SR10 for the precision you want.
See the link of the product http://www.futaba-rc.com/accessories/futm4150.html
Blackice504 says: Aug 16, 2011. 6:15 PM
nice design, how does the robotic arm sense the object it picks up?
i did not see if you used light or maybe a sensor of some sort.
i would love to make something like this but i cant cat plastic and wood work is so so, i think i will use some light steel.
vishalapr says: Jun 21, 2011. 10:10 PM
I was about to make an instructable on this and you made it...well...
PS118 says: Jun 21, 2011. 11:24 AM
This is so cool!
So are you using your own original design, then?
If so, would you mind attaching it? (Please, please, please!)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
