Introduction: Making a Cardboard USB Mouse!
Picture of Making a Cardboard USB Mouse!
In this tutorial we'll be showing you how to make a cardboard USB Mouse with an LED nose that lights up when plugged into a USB port!
At Bare Conductive, we love playing around with Paper Circuitry and enjoy sharing fun projects that we, or our community members have come up with so make sure you check out our website for more great projects!
Step 1: Materials
Picture of Materials
To do this you will need the following materials:
Bare Paint Pen
Drawing Pencil/Pen
LED
Cardboard
Ruler
Scissors
USB plug/port
Step 2: Step 1: Mark Your USB Contacts
Picture of Step 1: Mark Your USB Contacts
Using a ruler, mark two points on your cardboard which are 5mm apart. These will be the lines from which you will draw your Bare Paint circuit. These should be centered within two 12mm lines which will mark where you will cut the cardboard to fit into your USB port.
Step 3: Step 2: Draw Your Mouse!
Picture of Step 2: Draw Your Mouse!
Using a Bare Paint Pen, draw the circuit outline of your mouse. Make sure the two bottom lines are 5mm apart so that the tail won't short circuit in your USB port!
** Notice the gap at the top of the Mouse's head? This is to ensure your circuit works. Make sure you leave this space!
Step 4: Step 3: Attach Your LED
Picture of Step 3: Attach Your LED
Using your Bare Paint Pen, glue your LED at your Mouse's whiskers. This way it will make a lovely nose for your new pet.
Step 5: Step 4: Cut Out Your Mouse
Picture of Step 4: Cut Out Your Mouse
Using your scissors, cut around your mouse to outline its body. Remember the tail must be 12mm wide in order to fit into your USB port.
Step 6: Step 5: Let Your Circuit Dry
Picture of Step 5: Let Your Circuit Dry
Once your circuit is drawn out and your LED attached, let your drawing sit for 5 to 10 minutes until it is fully dry. Once it is no longer tacky at the touch you can bend the tail forward at a 90˚ angle so that your mouse will be upright when put into the USB port. If you think the corner may crack just put an extra dollop of paint in the crease to reinforce the bend of the circuit.
Step 7: Step 6: Now You Can Test Your Mouse!
Picture of Step 6: Now You Can Test Your Mouse!
Make sure the paint is 100% dry so that you don't introduce any wet paint into the USB port. Once you are confident it is dry you can carefully place your Mouse's tail into your USB port.
Step 8: Step 7: Watch Your Mouse Light Up!
Picture of Step 7: Watch Your Mouse Light Up!
Congratulations! You've made your very own USB Mouse!
Many thanks to Ross for sending in this great tutorial. If you have any projects of your which use Bare Paint and you'd like us to feature on our website, please email us your images to info@bareconductive.com
dvigatel (author)2015-07-09
Where is resistor? Or resistance of conductive paint is relatively high?
Bashie0101 (author)2014-11-20
Blew my led. Whoops.
shadowyblade (author)2012-09-09
Can I use any pen, or is Bare paint a certain kind of ink that just happens to be chemically formulated in a way that makes it conductive?
Hi Shadowyblade,
To answer your question Bare Paint is specifically formulated to be conductive. There are other paints that will conduct a current, however ours is the only one which is a totally non-toxic and consumer friendly material. No fumes, no rashes!
Conas (author)2012-08-21
awesome. Never heard of this Bare Paint stuff, but conductive paint sounds pretty fun
jessyratfink (author)2012-08-20
Very cute :D
About This Instructable
6,832views
27favorites
License:
Bio: Bare Conductive makes creative electronic tools for any designer, engineer or aspiring maker.
More by Bare Conductive:How to Make the Proximity LampHow to Make the Dimmer LampHow to Make the Touch Lamp
Add instructable to:
