3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making a Dagger from Found Materials! *UPDATE*
UPDATE: So... I have been getting better at this and have since made a machete and a new knife.  The new knife is made from a lawnmower blade and block of wood.  It was pretty easy, and came out with fantastic results.
All of my knives cost $0 to make.
Wow. It has been a while since I have posted an 'ible hasn't it? Well, I decided to post this: a guide on making a dagger from scrap materials. It was fairly easy for me, and experienced builders should have little difficulty making one using my method.
This dagger is made from a tent peg, bike inner tube, and scrap wood. Sadly, the tent peg is made from aluminum and not something such as steel, so it will not hold a sharp edge for a long time, but the dagger is still a great decorative product that can be given as a gift, used for a costume, or for actually cutting stuff.
Why a dagger? Well, I have seen many, many knife Instructables and sword 'ibles as well. I wanted a dagger! A large knife, but still not a sword.
So this is how I made my dagger! Enjoy, have fun, rate and comment! (Subscribe if you want to see me build a sword sometime in the future :D)
Step 1What do I need?
Well, I made up the process as I went along, but it still came out great. Here is what I used:
Tools
*Angle Grinder
*Ball-peen Hammer (sp?)
*A Large File
*Assorted Small Files
*Wood Saw
*Clamps
*Scissors
*Permanent marker
*Ruler
*Dremel w/ sanding wheel and cutting wheel
*Dental Pick - Can be substituted with a nail or other small pointy object
*Mechanical Pencil
*Rag
Materials
*Hardwood
*Bike Inner Tube
*Cheap Cardboard (found on cereal boxes, oatmeal, etc.)
*Tent Peg
*Wood Stain
*Polyurethane
*Epoxy/ JB Weld
*Paint Thinner/ Nail Polish Remover/ Alchohol
43 comments
1-40 of 43next »
Apr 6, 2012. 12:33 PMthok12 says:
Just made a wooden knife and found this. Thank you for the end of my spring break :)
Apr 6, 2012. 12:21 PMthok12 says:
epic. I'm so doing this.
Jul 14, 2011. 7:19 PMzombie1212 says:
very good I loved the first knife the one that looked like the hunting knife. I think I will make one.
Aug 8, 2010. 1:31 PM15zhangfra says:
have you tried leaving the parts that are on the base that flare out? they would be wicked hand guards.
Aug 6, 2010. 1:07 PMrenrawmit says:
You should try using a piece of heavy cloth (like canvas) to weather the wood, just to make it look cooler, like somone relied on it to stay alive.
Jul 31, 2010. 11:04 PMco2wms7whcc says:
This looks real nice and all and I like your handle wrapping method but an aluminum blade will not be able to hold an edge for long. I guess its better than not having a dagger when you need one! - Dr 0'Neil
Dec 13, 2009. 8:25 PMracoondawg says:
my uncle got arrested for  having one of these
Jul 31, 2010. 10:53 PMco2wms7whcc says:
Where was he when this happened and what was he doing?
Jan 8, 2010. 7:57 PMfoxtrot4697 says:
just for having it?
Jan 7, 2010. 10:04 AM{WAR}pikey says:
lol
Mar 13, 2010. 2:24 PMgoldenbacon says:
 haha
Feb 16, 2010. 4:18 PMJ@50n says:
Off to the garage haha!
Dec 29, 2009. 7:42 PMbulsatar says:
Even with the JB Weld, I would bet money that it will break from the handle the first time you strike anything with some density to it with some force.  I whole heartedly agree that it looks cool, but if you want something functional you will have to either
1) weld on a tang that runs at least 1/3 the length of the handle (preferably full length)
2) shorten the blade by a couple of inches and make the tang out of that.
Not trying to judge, but it is a matter of shear force on your weak spot (which is the connection between the wood and the steel) hitting it at the right angle.  Wider/Longer tang = better ability to withstand force  :)
Jan 15, 2010. 4:44 AMColonel88 says:
Yes, I agree to that,you should probably make a piece of metal the entire length, and then put two holes in one side, and then use pins to hold the blade to the handle. This way it should be stronger.
Dec 1, 2009. 4:12 PMraceryz350 says:
or recycle and use the metal an arrowhead.
Sep 14, 2009. 5:40 PMBright Shadow says:
I've got to try this sometime...
Sep 14, 2009. 5:51 PMBright Shadow says:
That's how all good things are made. Yay for screwing around!
Sep 17, 2009. 3:33 PMBright Shadow says:
New mechanism?
Sep 18, 2009. 4:45 PMBright Shadow says:
Can't wait to see it!
Nov 28, 2009. 10:51 PM19samman98 says:
please make a thing on your pen
Nov 7, 2009. 5:19 PMscottmiller says:
 Looks good but don't you think that it would look better if you wrapped the handle in a natural looking string? I mean you said that you wanted a medieval look and that might be better than electrical tape.
Sep 19, 2009. 8:39 PMbounty1012 says:
its more like a ninja's dagger.
Sep 24, 2009. 6:32 PMCamisado says:
No it's not. Ninja used either kunai or tanto, sometimes even a type of bo-shuriken. This isn't any of those.
Sep 24, 2009. 6:57 PMbounty1012 says:
>.> I meant it looked like one.
Sep 24, 2009. 7:23 PMCamisado says:
No it doesn't. A tanto is a katana-esque dagger, a kunai is actually a type of trowel, and a bo-shuriken is a throwing spike/needle. You just got pwned.
Sep 25, 2009. 2:12 PMbounty1012 says:
lmao.
Sep 3, 2009. 5:30 PMMatt21497 says:
Also can you post a pic of the other dagger?
Sep 15, 2009. 5:55 PMMatt21497 says:
Ok make sure you ACTUALLY post the pic alot of people are liars )-=
Sep 16, 2009. 6:39 PMMatt21497 says:
ok if ur busy u dont need to
Sep 3, 2009. 5:21 PMMatt21497 says:
definitely one of my favorite ones of your ibles
Sep 3, 2009. 8:17 AMChaplainAugustus says:
In step 5 pic 5 it looks like a penis... Ok sorry I had to mention it! This is a very cool knife and great improvising
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
220
Author:cowscankill(Check out my Youtube!)
"Don't find the time, Make the time." - gmjhowe 16/3/2009 He inspires me.
