Making a Drawing Machine From Record Players
5,403
81
6
Posted in TechnologyArt
Introduction: Making a Drawing Machine From Record Players
This Instructable was made by Mr. Mortensen's 3rd grade class at River Rock Elementary in Lehi, Utah. This is our first time making an Instructable, so we hope you like it!
PLEASE VOTE FOR US!
This isn't our idea, but it's our take on an idea we saw on a couple different web sites. If we knew the original creator we would credit them.
This spirograph drawing machine was fun to make!
Step 1: What You Will Need
2 record players
2 yard sticks
Hot glue gun
2 - 1inch square blocks
Pencils, pens, markers
A power drill
Various drill bits
Screw Drivers
1 1/4 inch screws
Hand saw
Small binder clip
Large pieces of paper (like poster size)
Tape
Chapstick
Step 2: Remove Record Player Lids
Depending on the record player, you may need to remove the lid or cover in order for this machine to work. The 2 players we had needed a few screws removed to take off the cover. Be sure to put the screws in a safe place so you can put the lid on if you ever need to.
Step 3: Wood Squares
If the wood you have isn't the right size, now is the time to cut it into 1" cubes. You will need 2 of them. The wood squares help you stay above the center rod on the record player and keep the machine from getting stuck.
Step 4: Drill Holes
Drill a hole that is slightly thinner than the 1 1/4" screws into both blocks of wood. Make sure that it goes all the way through.
Step 5: Hot Glue the Wood Squares
Now decide where you want to put the wood squares on the record player turn table. The closer you get to the center of the turn table, the smaller your drawing will be. We chose to put it on the edge of each wheel. Since we had poster board, we could do big drawings. Hot glue is the best option, because it pulls off easy so the record player can still be used for music.
Step 6: Drill Holes in the Yard Sticks
Drill a hole on one end of each yard stick that is slightly smaller than the head of your screws. This will keep the yard stick rotating nicely without falling off. Then drill a hole somewhere about half way down both yard sticks that is big enough for a pen.
Step 7: Cut Off Extra Length on Yard Stick
You can cut off the extra length of your yard sticks. They will only slow the machine down.
Step 8: Attach Ruler to Wood Block
Use your drill to put the screw through the hole on the end of the yard stick and into the pilot hole you drilled in the wood block. Don't go too tight, the yard stick needs to be able to rotate around the screw freely.
Step 9: Insert the Pen Into the Rulers
Align the holes you drilled half way down the yard sticks and push the pen through them. If it doesn't fit in, just grab the drill and make the hole a little bigger. Put the pen in and attach a binder clip from underneath to keep the yard sticks from sliding down the pen.
Step 10: Paper and Tape
Tape down your paper. You don't need to go crazy, just a couple pieces on the sides will do.
Step 11: Try It Out!
Give your drawing machine a go! After we tried ours, we learned that there was a little too much friction up on the wood block. So we add a metal washer between the block and the yard stick. We also put some chap stick on there to reduce friction.
Step 12: Experiment
Now that you have your machine running, try positioning your record players further apart, closer together, change the pivot points on the turn tables, etc. Have fun!
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    6 Comments
    Thanks! We'd like to try making the paper rotate as well.
    This is great!
    I don't think my 3rd grade teacher ever did anything even remotely as cool as this. Thanks for sharing how this went together! :)
    That's a great compliment. Thanks! We like to have fun in this class.
    I LOVE this! Such great critical thinking , creativity, collaboration and communication...all of the 21st century skills! I am absolutely hoping some of your current students will show this contraption (don't take it apart) at the STEM + Expo in September.
