Remove these ads by
Signing UpStep 1Materials
-Paper and Pencil
-Ruler
-Sharpee
-Tape
-Scissors
-Tiny #65 twist bit (0.035" which is good for most electronic components)
-Dremal or pin vise to drill holes, the Dremal is the obvious winner here
-Copper clad PC board
Materials to etch the board:
-Ferric Chloride(FC), which is used to etch the board
CAUTION Ferric Chloride is a very corrosive liquid the vapor well cause steel to rust, therefor one must take all precautions nessessery in order to protect yourself as it well cause nasty burns and alike. So therefore you well also need
-Rubber Gloves
-Safety Glasses
-Paper towels to clean up spillage
-A well ventalated work area as the vapor is also quite nasty and not good to breath in.
Aside from all the safety stuff you need,
-A small resealable plastic container to put the FC into for etching and storage afterwards.
-A larger plastic container that the small one well go into for water and storage of materials afterwards.
-Warm water, goes in larger container to heat the FC.
I used a uniball pen instead of a sharpie. Would that work or will I need a sharpie???
Oh well, Back to the drawing board.
Nail polish works but it is difficult to get even traces. Recently I bought a Testors enamel paint marker (available at Michaels or maybe your local hobby shop). I sharpened the wide tip to a point and proceeded to draw the circuit. Works like a charm. For IC's paint a bar for the the entire pin row then remove the paint with a knife between pin holes. I use a Radio Shack universal pc board as a drilling jig to locate the pin holes before painting. Use lacquer thinner to remove the paint.
Draw your circuit directly on the copper board and drill the holes.
Paint the Circuit with NAIL POLISH.
Then start the Etching process.
The Nail polish will save your circuit from being etched.
The places not covered by the nail polish will be eached.
Job done.
Washing soda is sodium carbonate
Baking soda is sodium bicarbonate
and baking powder is a mixture of baking soda, a alkali, and a dry acid such as cream of tartar.
None can be substituted for one-another. However, you can make baking powder using the recipe above.
Ahem
http://www.jtbaker.com/msds/englishhtml/f1080.htm
a simple MSDS sheet :P google is your best friend.
