Step 4Drawing the traces
-Using the Sharpie draw a solder pad around all the holes you drilled, helps to have a fresh pen with a sharp point for this, make sure the pen leaves a nice bold line otherwise it well not resist the FC as well.
-Now using the reversed copy of the layout as a reference draw in all of the traces with a Sharpie, if you make a mistake you can use alcahol on a bit of paper towel to erase the error.
-You can also use the Sharpie to add text to the board for connections or whatever.
-If you have not done so already, cut your board(s) out from the rest of the PCB stock.
Add Comment
