Making a Jewellery Bench
16,741
54
7
Published
Introduction: Making a Jewellery Bench
About: Retired technology teacher - 2 kids, I have an Hons deg in Design and Technology - 28 years as Computer systems engineer Trained as Electronics engineer in the Royal Air Force
Anyone who like me enjoys making jewellery will at some time wish they had a real jewellery bench to work from rather than the kitchen table.
Unfortunately the type of bench illustrated above - from cooksongold  costs £159, far beyond what I can afford or justify.
I would rather spend the money on materials I can then sell to make more money.
So I set out to build one for myself.
Step 1: Making Your Own
I bought a 4 foot x 4 foot  (1200 x 1200mm) bit of 12 mm thick MDF.
I cut about 100 mm wide strips from it to make the raised edge, your going to need this because when you work you will push expensive things off the edge of the bench.
I wanted a bench that was about  3 feet square (1000mm x 1000mm) This is a useful size and is small enough not to get covered in junk when your not using it.
Rather than make legs I decided to use a couple of saw horses I already had although it would be simple to make a couple up with 1 x 2 inch wood at a reasonable cost.
These set the height of the bench just right for me but if you make your own you can adjust the height to suite.
The catch cloth can be anything you have around I have used an old sheet before but this one is a length of fine window net I happened to have. It catches the things I frequently drop as well as the silver dust and small off cuts generated when making jewellery  - These can be recycled for cash through cooksongold.
Step 2: Construction
There is nothing fancy about the construction - The side rails are screwed onto the base and a semi circle cut out to form the working area.
You can attach your bench pin with a G clamp or like me screw it to the bench. The bench pin is made from some scrap beech plywood. Personally I prefer a wide bench pin as I find this more versatile.
The catch cloth is fixed with drawing pins to the underside of the bench.
The drawing has some dimensions on it but these are all changeable to meet your materials and needs.  I would however suggest you stick to the general design as this is a well proven design developed over years of use.
The semi circle was marked out with a pencil and length of string. Just by eye. This was cut with a sabre (jig) saw and the edges cleaned up with sand paper.
Other than that there is nothing else to this project - I tend to clamp the bench top to the saw horses to make it more stable but this could just as easily be used on a normal table top to protect it and then removed and put away for next time.
Step 3: A Few of the Things I Have Made Recently
I tend to experiment with things that attract my interest. This may lead to a finished item or may not. I rarely make two things the same.
In many ways this is an advantage as my clients see my jewellery as unique.
For materials i have used paper, painted and stiffened with PVA glue, Cork, wood and Sculpty (fimo) all to some success.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    7 Comments
    Thank you for these easy to follow instructions. I shall have a look in my shed to see what I can find to make a bench like this; actually, I'll need a bit of help in the assembly, but that can be arranged. Perhaps I could add hinges to make it a fold away bench? I never thought of a catch cloth before, mainly because I do my beading on a tray with a piece of felt on it at the kitchen table. Sometimes beads and other components bounce down onto the floor and are lost, so the net idea is particularly useful!
    You very welcome. The catch cloth is a real benefit if your clumsy like me.
    I didn't make legs because this lives in the garage so saw horses are already there and the right height because I work sitting down. Putting legs on it isn't a big deal though.
    have fun.
    thank you i have also looked at cookson, but i can make this with these great instructions !!!
    i am going to give it a go and i will let you know how it go's .
    Really like the knitting, knots and bone - similar set up to mine, thank you for sharing.
    I buy almost all my materials from Collingwood link in the indestructible.
    Yes copper can be post plated lots of plating companies can do it at moderate cost. Rhodium is also a good finish.
    Silver plated copper is fairly common on line jewellery sites in various gauges
    Amazing .... really nice art !!!
    Thanks for sharing :-)
    And the bench with catch skirt is a great work area.
    When I think how much time Iv spent on my knees with a laser
    trying to pick out a tiny screw from the accumulated clutter..
    Seriously thinking to make a smart motorized catch skirt to automatically slide around me
    when I sit and then withdraw back under my work spot when the chair starts rolling back.
    Do you buy the Ag plated Cu wire or make it yourself ?
    Could it be post plated ?
    A
