Making a Log Drum With a Laser Cutter
Introduction: Making a Log Drum With a Laser Cutter
A log drum consists of a resonant box with a top striking surface with two different sized tabs. The two tabs produce two different notes when struck. This log drum was designed as a set of interlocking plates in Inkscape and then cut on a laser cutter.
This log drum was designed as part of the WAVES project, a collaboration designed to explore the common ground between STEM education and the Arts (sometimes called STEAM). Here's a link to an Instructable on WAVES.
Explore in the model in Fusion360.
Step 1: Making Music With a Log Drum
Peter Martin of Third Coast Percussion explains making music with a log drum.
Step 2: Installing Inkscape
Inkscape is a great free 2D drawing program that has much of the functionality of Adobe Illustrator. Inkscape runs on Windows, Mac, and Linux. It can be found at
Installing Inkscape on Windows
On Windows, you can install Inkscape just like any other application. Go to the Downlads page at to get the installer.
Installing Inkscape on a Mac
On the Mac, Inkscape runs under a graphics environment called "X". Prior to Mac OS X Mountain Lion (version 10.8), X was installed by default. Beginning with Mountain Lion, and then Maverick, if you want to run X programs like Inkscape, you'll need to install a version of "X" first. The following notes were taken from this link:
  1. Install Inkscape (if haven't done so already) from
  2. Install XQuartz from
  3. Run Inkscape
  4. When asked for "Where is X11?", click "browse ..." and select /Applications/Utilities/ (or just /Applications/Utilities/XQuartz)
  5. Note that if XQuartz starts up when launching Inkscape, but Inkscape doesn't launch the first time along with XQuartz, (or the Inkscape window doesn't show up), you can try to quit both Inkscape and XQuartz, then launch Inkscape once more (which should also launch XQuartz). This bug occurred on the system that the above fix was tested on, and the workaround seems to have worked. Your mileage might vary.
Step 3: Using Inkscape to Design a Tabbed Box
Our log drum is designed as a tabbed box that is glued together. We use 1/4" thick Baltic birch plywood, available from most "big box" home supply or hardware stores. The video shows the basic methodology for designing a box that will line up properly.
The best source of information on using inkscape is the online manual
Before you do anything (unless you're the type that doesn't read manuals), go through the first three Quick Start sections in the manual
Laser cutters require that lines have certain properties (color and thickness) so that they can be recognized for cutting. We use an Epilog 36EXT laser cutter in our shop, which requires that cut lines be pure red and have a thickness of 0.001". The second video shows how to set these line properties in Inkscape.
Step 4: PDF of Completed Design
This PDF file contains a completed design for a pair of log drums, that fits nicely on a 2' x 2' sheet of 1/4" Baltic birch plywood.
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    The Drum your trying to make is a Sacred Drum to many indigenous Cultures around the world, Our people are the Taino of the Caribbean and the drum is called the Mayohuacan, I ask that the spirit of this Sacred object be respected and enjoyed. I've made many Drums and your on the right direction, good luck.
    Blackraven, thanks much for the info on the Mayohuacan and Taino music. I love the way that you tied the words "sacred," "respect," and "enjoy" into the same sentence. I have found several very nice videos on Taino music and the Mayohuacan on YouTube. Here's one:
    If anyone knows of other indigenous instruments of a similar design, please share!
    or the box maker
    Raptor, never heard of boxmaker before. Thanks for the tip!
    Thanks for posting a "how to" for Inkscape
    What a great idea! Good getting started with Inkscape tutorial too.
    Very nice work!
