Step 2This is the Code, DO NOT COPY AND PASTE
........NOTE........
because of some annoying auto-editing that instructables does, the code as seen on this page WILL NOT WORK, you HAVE TO DOWNLOAD THE FILE I attached instead of copying and pasting this.
//This was written in c++ by leevonk
//it is code for a matlab mex file
//the code will take in one number value and output two number values
//the two output numbers are calculated from the input number
//the code will also output a string value
//the code will also print "hello world"
#include "mex.h"
void mexFunction(int nlhs, mxArray *plhs[],
int nrhs, mxArray *prhs[])
//#######--print "hello world"--############
mexPrintf("Hello world");
//########--Get Stuff From Matlab--#########
/* declare an array variable to hold the incoming vales */
double* InValues;
/* get the values sent from matlab */
InValues = mxGetPr(prhs[0]);
/* to use these values that were sent from matlab, do InValues[0],InValue[1], etc
according to how many values there are. The InValues will be used below */
//########--Return a number array--#########
/* declare the array that'll be sent to matlab (the * makes it an array) */
double* OutValues;
/* Create/allocate return argument, a 1x2 (1 row 2 column) Matrix
for the return array's first slot (plhs[0]) */
plhs[0]=mxCreateDoubleMatrix(1,2,mxREAL);
/* Get pointer to the return argument */
OutValues = mxGetPr(plhs[0]);
/* assign values to OutValues which will reside in the return array's first slot,
here we're using the InValues to computer the OutValues */
OutValues[0] = InValues[0] + 1;
OutValues[1] = InValues[0] + 2;
//###########--Return a String--#############
/* declare the string variable to be sent to matlab */
char* str;
/* assign a value to the string */
str = "byebye";
/* put the string into the return arrays second slot (plhs[1]) */
plhs[1]=mxCreateString(str);
//###########--return more stuff--############
/* to return more stuff, follow general rules above but put
the stuff into other plhs slots, plhs[somenumber] */
mextest1p0.cpp2 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
