Making a Motorized Secret Entrance
 by flaming_pele!
Contest WinnerFeatured
If you're decorating along the lines of a haunted house or a superhero lair, a secret entrance is just the thing to get Halloween guests into your home. In our case, we threw a Superhero costume party and wanted to build a motorized, moving wall activated by statue - a nod to the Batman series of the 60s.
Goals:
- Surprise guests with an apparently closed room as they walk in
- Give them a riddle to figure out how to open the hidden door/wall
- Keep the area this occupies to a functional minimum so it doesn't take up too much actual entertaining space
Step 1: Planning the Layout
We have a tiled area at our front door which defined a natural boundary for our fake room. The area is large enough for 2-3 guests to comfortably walk in and move around, and small enough that it doesn't occupy too much of the (real) room.
We decided that walking in from the front door, into a tiny room with only walls wouldn't seem very plausible. To help sell the illusion we hung a door in front of you as you walk in, but boarded it up, so the room appeared as a small vestibule which was no longer passable. We left the knob off this door, just to keep guests from trying to go through it (despite the boards). Which leads me to a point about safety...
Step 2: Framing and Safety
It's important to realize that guests may push on any wall, looking for a way in, and you don't want anything collapsing. Sometimes Halloween props can be flimsy and just for looks; this isn't one of those times. So I took care to build a sturdy structure framed mostly with 2x4s. Given our particular geometry, and materials used, we got away with only anchoring one top corner to the actual wall with a single screw.
For the section of the wall that makes up the secret door, we used lighter materials so the job of moving it would be easier on the motor. It consists of just one 2x4 on the edge where it hinges, a 1x3 across the top, a 1x4 across the bottom, and a lightweight 2x3 steel stud on the side that moves. Since this section was light, just two hinges were used to connect it to the other framing.
There's about an inch gap at the top and bottom of the framing of this section, so there's plenty of clearance to move. The gaps would be covered once the "walls" were added.
Step 3: Walling it in
The walls and a false ceiling were added with panels of pink insulation foamboard. It's lightweight, easy to cut, hang, and paint, plus easy to re-use for a different project later. Two inch masking tape works great to cover seams and screws - in spooky lighting it disappears nicely.
You could do any faux paint finish inside - we just painted everything white to blend with our existing doors and (real) walls.
Step 4: Adding the Wheel and Motor
A small 12 volt motor was used to motorize the door. The motor came with a gearbox with an  output (free) speed of around 60-90 rpm. A motor that's nicely geared down is what's needed here - for one, you don't want the door moving too fast, and the gearing lets you use a pretty small motor. Once everything is hooked up it takes the motor about 6-7 seconds to open the door. The slow speed helps give the illusion that the wall is very heavy, plus it's safe in case anyone is standing too close on the other side.
The wheel is a hard rubber wheelchair wheel salvaged from some past robotics projects.
The wheel and motor were mounted so the wheel extends below, and supports, the bottom of the door framing.
Step 5: Electrical Work
The motor is powered by a typical 120vac-12vdc adapter. I mounted a double pole, double throw (DPDT) switch outside of the fake room to operate the door in either direction.
To open the door from inside the room, two limit switches were mounted just under the base of a statue (see the photo). The switches are wired as "normally closed". When the statue is resting on the switches, they are open, and they become closed when the statue is tilted. Two switches (rather than one) were used because it was an easy way to tie into the existing circuit with the DPDT switch.
Step 6: Finishing Touches
Some final details really help to pull everything together. Also, the surprise of the wall opening is heightened if the lighting/decor is different on either side of the room. Inside, we added some webbing and LED candles inside for a run-down, creepy atmosphere. Outside we had different colored lighting and decorations.
We marked the swing of the door with an arc of gaffers tape on the floor. This would keep our guests aware of not standing too close as more people come in.
The final touch was a small riddle inside to give guests a clue of how to enter.
1-40 of 56Next »
eulaliaaaa! says: Nov 7, 2010. 7:36 PM
Sweet! Love the riddle!
D00M99 says: Nov 7, 2010. 9:03 PM
This is AMAZING! Totally creepy.
And the front door squeaks too!
MCUman says: Nov 11, 2010. 8:47 AM
Rig some candle sconces with a switch, that way you can yell, "Put za cendle BECK!" to get the door to open.
RaNDoMLeiGH in reply to MCUmanNov 11, 2010. 6:56 PM
I was just thinking something like that when I saw your post.
Coffee+monitor=five stars for you.
MCUman in reply to RaNDoMLeiGHNov 12, 2010. 12:21 AM
Great minds...!
enagel3 says: Mar 23, 2013. 9:37 PM
interesting
sofiadragon1979 says: Jul 11, 2012. 3:55 PM
I've been trying to think of a way to set up a neat entrance to a dark room & I think that this might be a good idea.
tinker234 says: Feb 20, 2012. 11:58 PM
could this be setup to run all year long under the floor possibly
caarntedd says: Oct 20, 2011. 11:12 PM
I think I gave this 5 stars last year, have another 5. Awesome.
scraptopower says: Oct 20, 2011. 1:38 AM
Nice work!
Mella2013 says: Sep 15, 2011. 6:22 AM
Awesomeness
battle says: Nov 17, 2010. 2:29 PM
What if someone else is in the room with them and they both find out then someone else comes in and people just watch the other people in front of them to find out what to do and it just keeps going on? Because thats not in the instructable!
P.S Know that you shouldn't start a sentence with because
SuperCoPilot says: Nov 16, 2010. 7:46 PM
i may have screamed in glee a little, just a little
JermsG says: Nov 13, 2010. 7:11 PM
Minor typo:
"Two inch masking tape works great to cover seems..." - I think you mean seams.
=8-)
flaming_pele! (author) in reply to JermsGNov 15, 2010. 9:29 AM
Thx, fixed!
warlock1935 says: Nov 12, 2010. 6:09 PM
OK, now we know how the guests OPEN the door. How do you get it closed again? Manually?
flaming_pele! (author) in reply to warlock1935Nov 13, 2010. 6:19 AM
There's a switch on the other side (after you walk in) that can open or close the door (see the video in the intro and the pic in step 5. I didn't see a need to close it from the other side, but there are certainly ways to do that if needed.
the3stoogess in reply to warlock1935Nov 12, 2010. 10:24 PM
why not try using a motor that turns either way. and rig it so that when the statue goes down, it automatically closes. and once the wall reaches its end point, just make a strip that it can connect to so that it will tell the motor to shut off. just play around with the wiring and it should work out pretty easily
battle says: Nov 8, 2010. 7:52 PM
so you have a camera so that you can see when someone makes george say yes and then you pres the button
Shiftlock in reply to battleNov 11, 2010. 7:24 AM
Instead of asking a question like this (if it was a question - not sure due to lack of punctuation), why not just look at the entire instructable? The answer is in there. As it turns out, your assumption was wrong, and it really makes you look a bit daft.
3DMHuff in reply to ShiftlockNov 13, 2010. 5:47 AM
I think it was more of a suggestion than question.
fungus amungus in reply to battleNov 9, 2010. 4:11 PM
step 5. there's a switch under the head
goblindust says: Nov 12, 2010. 2:38 PM
Excellent!! Must keep this one in mind for next years Halloween! Many thanks for sharing the great idea.
janettetsmith says: Nov 11, 2010. 9:55 AM
Incredibly cool!  What about after Halloween, did you tear it all down :`( or is it now a permanent remodeling.  Again, very cool.
flaming_pele! (author) in reply to janettetsmithNov 12, 2010. 8:11 AM
Sadly I took it all down a couple nights ago. We got to enjoy it for about 3 weeks, though. All the raw materials are back in the garage for reuse next t Halloween!
rexdino5 says: Nov 11, 2010. 7:28 PM
Do you have a video of this or did you already rip it down?
flaming_pele! (author) in reply to rexdino5Nov 12, 2010. 8:08 AM
A video is embedded in the Intro.
ghostWolf59 says: Nov 11, 2010. 6:10 PM
the strip in the floor gives it away and make it look pretty bad
The extra door doesn't make mush sense either. A secret panel next to a door - sheesh
Nachoman in reply to ghostWolf59Nov 11, 2010. 6:27 PM
It's supposed to be a secret door. It doesn't mater if its unpractical or if it looks tacky on the inside: What matters is that it should look like another section of wall on the other side.
Besides, is for amusement. Haven't you ever given a kid a toy that does nothing but make noise?
I guess you must have had a pretty sad childhood...
Charlie13 says: Nov 11, 2010. 3:34 PM
i'm definitely incorporating this in the house that i build for myself
mattyh says: Nov 11, 2010. 1:12 PM
Man thats soo Awesome! that would make cool additional to my nerd cave / smoking room.
bsteines says: Nov 11, 2010. 8:24 AM
Where does one get a motor with gearbox (servo) that big?
flaming_pele! (author) in reply to bsteinesNov 11, 2010. 12:08 PM
Check ebay listings for 12volt motors, some of them come with gearboxes. My motor is from Johnson Controls, there's always lots of them floating around online.
See if you have any local mechanical/electronics surplus or salvage stores near you. Look for motors you can rip out of old toys, tools, etc. Old cordless drills are great for projects like this!
connor123 says: Nov 11, 2010. 11:11 AM
HOW DO WE NOW ABOUT THE ELECTRICAL BITS
IMQuestor in reply to connor123Nov 11, 2010. 11:28 AM
read step 5
Shiftlock says: Nov 11, 2010. 7:50 AM
Amazing. Seems like s a lot of work for a Halloween party. You basically framed out what could be a permanent wall and door. I always envy people who go overboard with holiday decorating. Awesome job and nice write up.
Couple of questions. Is there anything holding the statue to the base? How long did the whole project take you, and approximately what did it cost in supplies?
flaming_pele! (author) in reply to ShiftlockNov 11, 2010. 9:52 AM
I added an extra sketch to step 5. The front edge is just taped down. It's enough to keep someone from lifting it off or it getting misaligned to where it'd miss the switches.
gdhenson says: Nov 9, 2010. 3:02 PM
My wife would beat me purple if I tried to do something like this.
flaming_pele! (author) in reply to gdhensonNov 11, 2010. 7:57 AM
LOL!
I'm lucky, not only do I *not* get beat purple, but she helps with the crazy.
gdhenson in reply to flaming_pele!Nov 11, 2010. 8:07 AM
See. That's what I get for marrying for money.
1-40 of 56Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
