Introduction: Making a Mushroom Log
This is my first time growing mushrooms.  It's a fair amount of work up front but the payoff will be exciting!
Step 1: Selecting Wood and Materials
Research what kind of wood you will need (Hard or Soft) as it depends on what mushrooms you are growing.  Finding the wood was the most challenging step until I spoke with a tree trimmer and it was a couple of weeks.  I am growing Shiitake mushrooms so I chose Oak.  (I bought my mushroom plugs from http://www.easygrowmushrooms.com/ )
Materials---
1 Tree limb, 4-6 inches in diameter
30-50 Mushroom Plugs
Electric Screwdrivier
5/16 Drill bit
Rubber Mallet
Masking tape
Sharpie
Organic Beeswax
Disposable Paintbrush
Camp stove (to melt wax outside)
Something to rest logs on to make easier to work on
Step 2: Make It Easy on Your Back
I used two ladders to hold the logs up to work on them.
Step 3: Cleaning the Logs
If your log has any lichen or anything on it please clean it.  Any fungus will compete with the mushrooms so clean well.
Step 4: Measure the Depth for Drilling
Look at the end of the log and calculate the depth of the plus plus the thickness of the bark.  Mark the drill bit with masking tape as a guide for how deep to drill each hole.
Step 5: Spacing
Space the plugs approximately 6inches apart in row and offset each row
Step 6: Hammer in the Plugs
Using the rubber mallet hammer in each plug until fully inserted.  Plug can be level or slightly sunken in
Step 7: Wax
Melt the beeswax.  I used the double boiler method to melt the wax and keep it from burning the plugs.  Use a disposable paintbrush to cover each plug.  This helps keep moisture out and protect the plug.
Step 8: Finished
You are now finished. Store in a damp shady spot and wait. You can also cover with canvas and water to help with moisture. Enjoy!
