Step 5Yank out the IR filter
Then pop all the layers back on (make sure that thin black circle thing isn't blocking the lense). everything popped back together securely so I didn't use glue or anything.
Then put the lense assembly back into the blue ring thing and screw the whole thing back ontop of the CCD. Screw back the case, you're done.
I discovered that the Infra red filter to be very fragile, i managed to shatter it with a jewellers screwdriver. Then it was a simple matter to prize the small bits of glass out of the lens assembly, wear safety glasses when doing this!
The IKASU has 6 white LED's on the front which are operated by a photocell, im tempted to replace these with 6 Infra red LED's to see what the results are like.
