The construction is done with a technique called “stitch-and-glue” and is built from thin plywood. The stitch-and-glue (S&G) method use plywood panels cut to shape that are temporarily wired together with copper wire. This wire is the “stitches”. With the panels held in their intended shape with the wire the plywood is permanently glued together. The wires are removed and the whole thing is covered in a layer of fiberglass cloth and the cloth is saturated with epoxy resin to make it strong and waterproof.
The preferred material for this construction is 4 mm thick okoume marine plywood, covered with a 6-ounce per square yard fiberglass cloth coated with an epoxy resin. This will provide the strongest, longest lasting construction, but if you are strapped for cash, you can substitute lauan “door-skin” for the okoume and polyester resin for the epoxy. Lauan is apt to have gaps in the interior veneers that make the plywood. These gaps can weaken the material and may accumulate condensation leading to rot, but with a little care in building and storage when you are done lauan can make a nice boat. The description of techniques in these instruction assume epoxy resin, you may need to adjust your technique if you opt to use polyester.
Remove these ads by
Signing UpStep 1: Prepare the Plywood Sheets
First you need to form the scarf shape. Your plans will provide guidance on how to cut the plywood, you can just go ahead and scarf 2 full sheets, but these can be hard to handle. You may want to cut the plywood down into smaller sizes so it is easier to move around.
Stack the plywood with the edges you want to scarf aligned on one side. Plywood often has one “better” side. Flip over one of the pieces so on one the better side is up and on the other the better side is down. This way you can the better side up on both pieces when you glue up the scarf. It will help get the scarfs even if you have a piece of scrap plywood the same thickness on top and bottom. Stagger the edges back 1 inch each to make a shallow stair case. Clamp this down the edge of your workbench so the bottom layer hangs of the edge by a small amount.
One of the best tools for cutting the scarf is a sharp block plane, but you could do this with about as easily with a belt sander. If your plane has not been sharpened in the past 24 hours is probably needs to be touched up. If you have never sharpened it, you definitely need to give it a through sharpening.
Use the slope of the stair steps as a guide as you plane down the stairs. Cut into each step evenly, trying to keep the amount of material you have sliced off each layer even and consistent. The goal is to make a smooth, flat, wedge all the way from the top to the bottom. If you that the planed area on on one layer is getting wider than the other layers, adjust your planing to make them even again. As you plane deeper into the plywood you will start to see dark stripes and then the wood may change color a bit. The dark lines are the layers of glue between the plies of the plywood. Use these glue lines as guides to help assure a straight flat surface. Work to keep the glue lines straight and parallel. If you see part of the line curving up higher than on either side, plane down the sides to bring the rest of the line up even and straight.
You are done cutting the scarf when the side of the plywood has sharp edge and there is no step down from one layer of plywood to the next. Give the surface a quick sanding with 80 grit sandpaper to promote a good glue bond. Take one sheet of the plywood and flip around to the sharp edge is facing the other way and the bevel is facing down. Put a strip of wax paper under the joint. Mix up some epoxy and then add your powder to make a mayonnaise consistency glue. Spread this on the planed surface. Line up the joint so the two wedges overlap 1” such that the thickness is consistent throughout. Place a layer of wax paper on top of the joint and pile some weights to clamp the scarf tightly.
When the epoxy has cured, peel off the wax paper and scrape and sand off any rough spots. Don’t sand into the wood around the joint.
Drawing the Panels
If you down load the free plans you will need to graph out the dimensions at full size. These dimensions are sometimes called "offsets" This will take a large sheet of paper such as Rosin Paper you can get at hardware store or home center. Mark out the dimensions for each panel on the paper with little "x"s. Push some "T"-pins into the x and bend a narrow, flexible wood strips or fairly stiff wire around the pins to create a long smooth curve. Mark along this spline to draw the edge shape. You can fold the paper in half to cut out the symmetrical parts.
Layout the Panels
Cut out your paper patterns from the plans. Lay the patterns on the plywood as suggested by the plans. If you find a more efficient layout of the patterns, feel free to use it, but on the long panels you want the grain of the plywood running down the length of the long axis as much as possible. With the parts that require you cut two, such as the hull sides and front deck, lightly mark out the location with a pencil of both sides before doing any cutting. You want to make sure you arranged the parts correctly to get both pieces. Plywood generally has one better side, flip the pattern over when you layout the other side so you will have the better plywood side showing on both sides of the boat.
Once you have determined exactly where each part will come from, tape down the patterns so they don’t move. Make sure the paper is smooth and flat, without wrinkles or bumps or lifted areas.
Use an awl or sharpened nail to punch holes through the paper along the edges of each part into the plywood. Make the marks deep enough so you will be able to see them later. Make the marks as close together as necessary to assure you will be able to reproduce the curve accurately. This may be every 3 or 4 inches in straight areas, or ever 1/2 to 1 inch in places with tight curves. The patterns have little “+” marks with circles that indicate wire stitch holes. Use a 1/16” drill to drill out all these holes right at the crossing point of the lines.
Use a pencil and flexible strip of wood to connect the awl marks. Make a dark line that will be easy to see when it comes time to do the actual cutting.
Before you do the final cutting loosely cut out the parts where you will be making to matching pieces. Use a power jig saw to do the cutting. Install a new, fine tooth, smooth cutting blade in the tool. Cut outside the line but pretty close. Be aware of where you will be cutting the other side so you don’t cut into the area you will need for that other side. If you roughly cut out the marked piece first you can use it as a pattern to trace for the other side. With the two pieces cut out lay the marked on on top with the marking showing. Drill through the stitch holes of the first side into the other side. Push a small finish nail or brad through the holes as you drill them to keep the panels from shifting. Now, use your jig saw to cut out the final shape. Cut just on the outside of the leaving half the line. If you are uncomfortable cutting that close, leave more of the line and then come back with a block plane or sanding block to even out the edge and remove half the line.
Cut all the pieces in a similar manner. Work slowly and carefully. While the Jupiter Point boats are more tolerant of a little inaccuracy than other S&G designs, good, accurate cuts will make assembly easier and assure the finished boat is the desired shape.
Visit Our Store »
Go Pro Today »
Another option if you are willing to go with alternatives is: just about any cloth can be wet out with resin and bonded to wood to provide reinforcement. So old cotton sheets or muslin could conceivably be used. Historically boats have been covered with canvas to good effect.
If you are looking to go really alternative, consider using tri-wall cardboard instead of wood then reinforced with fiberglass or muslin. You would want to make sure that all the edges of the corrugation were well sealed. But if you are willing to think "outside the box" a bit, there are many alternatives.
Lastly, the epoxy resin could be substituted with polyester resin, or going further afield diluting a polyvinyl acetate glue such as titebond or titebond III could be create a workable alternative with a little experimentation.
thank you for this generous instructable!
The offsets are very clear and logical.
Can you tell us what the beautiful red plywood was used on the child's kayak?
Or is it a red stain over a light-coloured ply?
I think it's just delicious!
Shas
Is the 7' child's kayak plan also free on your website?
I could not locate it.
I've dreamed of building one of the Chesapeake Light Craft kits for years.
Your Instructable may be the inspiration I need to actually do it.
I am going to make the Io fore my yongest son.
How much fiberglas and epoxy you think I need fore Io?
I have made 2 boats: Ponnt Bennet 17,5 fore and Chesapeake 14 fore my 11 year old son.
Now this winter I am going to make the 14 Foot Great Auk (got the plans from CLC) fore my 8 year old son but after seeing this instructabule I am first going to make Io for my 5 year old son
Bulding kayaks is realy fun... :)
Io makes sense now that you point it out (I thought it was Lo.)
Io and Ganymede are now bringing back memories of Astronomy 101.
Thanks
I will use some of your techniques for my next project :)
