3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making a Powerful Linear Actuator
I looked at buying a Linear actuator but they are too expensive for the project i wanted to do so I thought i would make one and document it for Instructables so that others can follow what i do for their project or improve on it.
I have 2 options for you guys here, the frist option I tried and a slightly improved model.
Step 1What you will need
What you will need
  • last photo ←
You will need the following materials and tools
Tools:-
Welder - Optional
Hacksaw - a junior hacksaw is fine
flat head screw driver
vice - i used a hobby vice which was fine
Mitre block
Hammer
a metal file
Materials : -
Epoxy Resin - Araldite is what i used
threaded rod - M10
Nuts - M10
piece of clothes rail
clothes rail holder
DC Motor or a Cordless Drill with forward and reverse
Petroleum jelly
6 comments
Dec 28, 2011. 7:49 PMheathbar64 says:
You will find some very useful gears in an old kitchen mixer. they have a worm gear and two ring gears to go on it. this could mount the motor perpendicular to the screw.
Nov 24, 2011. 3:34 PMespdp2 says:
I like it. I have some ideas that could use that. What have you used it for? And roughly how powerful is it?
Apr 25, 2011. 11:44 AMzack247 says:
very cool!
May 30, 2011. 1:55 PMDeadlyDad says:
If space isn't a problem, what about using bicycle sprockets and a short piece of chain? Heck, by using two different sizes, you could change the speed of actuation at the same time. You could also try stopping by a garage or photocopier repair place. Either should have junked strong gears that would do the trick.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:n1cod3mus(Chris Fry Design)
I'm a web developer, IT engineer, Graphic Designer. I have a creative nature and an over reactive imagination which is perfect for instructables.
