Making a Proper Swiss Army Knife With Popsicle Sticks (normal Size.) V2.0
343
5
10
Published
Introduction: Making a Proper Swiss Army Knife With Popsicle Sticks (normal Size.) V2.0
what's new in v2.0
there's a ruler in inch scale
there's a saw
This is a step by step easy tutorial and this is made of very cheap materials. Please edit it and upload images. I don't know how to stop it. Please subscribe.
Step 1: Required Materials:
6 small popsicle sticks
a clip
an adhesive
a paper cutter
a ruler
sandpaper
a sitck or toothpick
a drill or board pins
a pencil
a paint
a brush
let's make it!!
Step 2: Cut the Sticks
cut 6 sticks with 7.4cm or 3.5 inch length. We'll need the remaining in another step.
Step 3: Make Holes
drill a hole on a stick and place that stick on top of the other and make holes on all the 6 sticks like in picture 3.
Step 4: Carving the Knife, Ruler and the Saw
first let's begin with the knife. see picture 1 2 and 3
cut off 0.5 cm and then carve the knife
now the ruler. cut 0.6 cm and cut it a little cross as in picture 4
mark inch or cm measures as you like. I'm doing inch. see picture 5.
finally we gonna make the saw.
cut short piece as we did in ruler but more steep.
draw triangles in it and cut it. see picture 6 7.
Step 5: Make the Blocking Piece for All the Tools
Insert the stick to one side of the handle and the blade. refer picture,mark the blocking piece like picture 2. take the piece which we have cut in step 2. draw the same in that piece . cut what we have drawn on the remaining piece in step 2. don't cut the handle. even if it's cracked it's alright. because we will stick it in the handle which we have drawn. clip it and allow it to dry.
like the same do it for the ruler like in pics 4 5 6
repeat that for the saw.at final it'll look like picture 7
Step 6: Assembly
it's time to assemble follow picture 1 and do that.
at the last blocking piece apply some adhesive and stick it to the handle as seen in picture 2.
Step 7: Painting
paint in any colour.
Step 8: Making the Logo
make the logo as in picture. That's it your swiss army knife replica is ready. Thanks for spending time. please subscribe. and if I get 1000 views on both the tutorials then I will make v3.0. Make sure you check out v1.0. just type this same name without v1.0
Happy making!!!!
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Stick It! Contest
      Stick It! Contest
    10 Comments
    excited to make this with my boys! Can you explain a bit how the pin is finished? I assume you cut off the top part so the blades can open and close.
    can u explain it with pictures
    yes, the pins that the blades hang on. I can see from one image there is a push pin, then something longer sticking out. Then in another image it is now flush with the wood Do you just glue a push pin in then trim it down?
    no its not the pin. I just used the toothpick like stick
    Ah, that is great. Thank you so much for taking the time to put this together and respond to my questions. Keep up the fantastic work!
    Thank you. Please post the picture of yours. Happy Making!!
    didn't get you
    yeah but I have to buy a silver one
    Thanks for spending time in the comment section too
