3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making a really simple rabbit trap
  • last photo ←
Even in the urban garden Rabbits are a real problem. Many people dislike the thought of shooting or it may not be practical if close to houses so a  live trap is a good alternative.
In this instructable I will show how to make a simple and cheap live trap.
Just remember if you release the fluffy bunny then take it at least 5 miles from your house or it will come back!
Step 1
Materials:
A length of wood - Sizes are not critical but should be at least these sizes or the rabbit wont fit in the trap
36 inches - 900 mm x 10 inches - 250 mm x 1/2 inch - 12 mm
Some stiff wire - I used some square mesh left over from a rabbit hutch (irony there)
A few staples
Some left over scraps of wood laying round the work shop.
Tools:
Saw
Wire cutters
Pliers to bend the wire mesh.
54 comments
1-40 of 54next »
Mar 17, 2012. 3:59 PMrmcqcc says:
Great write-up. I'm just having a lot of trouble visualizing how this trigger mechanism works. It just doesn't seem to make sense. Is the concept that the vertical piece just moves back off of the horizontal, thereby releasing the horizontal piece? If it is supposed to pivot, I don't see how it releases the trigger.
Feb 17, 2012. 5:50 PMkingmii says:
Thanks heaps I'm going to make some modifications so I can use it for possums (Not Opossums Australian possums that are a major pest here) live traps for possums cost $150 so if it works you'll be saving me heaps
Jun 20, 2011. 7:34 PMalterator says:
You could have made the release more efficient. This setup may fail and not release the door. Something electric maybe. When I made my mouse trap - I used 9v battery and usual 12v motor from a car radio or something. hot-glued bamboo stick to motor rotor..
as for the trigger -- there was something like a rectangular bridge or ramp, so - when the mouse stepped on the ramp, motor turned, pulling the stick up, which was holding the door and releasing them.
materials were:
plumbing pipe,
2 slim cd covers - 1 used for back, other with a hole cut in the bottom was glued in fromt, so that when the case is closed, it acts as the door for the pipe.
motor
9v battery
bamboo stick
and a hot-glue, of course! :)
should have made the ible though, would be easier to see for Yourself.
Feb 4, 2012. 5:42 AMMr.1911 says:
I agree entirely with the simple mechanics statement.
Oct 30, 2011. 4:04 AMKryptonite says:
Neat Instructable!
I love how simple it is. I liked the last step, and I thought I'd point out another way to do the same thing without having to whittle down sticks quite as much.
  • With two sticks both having a notch cut into the end, one of which having the other end pointed, and another stick to hold the bait you can do the same thing.
  • Drive the sharpened stick into the ground with the notch pointing skywards.
  • Place the bait stick between the two notched ends pointing inwards, and finally balance the basket / box / rock on top.
  • When the bait is taken, the sticks unbalance and cause the box to tople.
ASCII diagram!
============== box
ll      stick
^      notch
-------- bait
v      notch
ll      stick
v       point
Nov 2, 2011. 3:11 AMKryptonite says:
I, personally, have found dead falls harder to deal with as a sizable rock is no where near as easy to set by one's lonesome, but a rock on a box / net set up works a lot better, while of course having to kill the animal yourself.
Snares work sometimes, but to be honest I believe that rabbit traps (despite the downsides) are the best for trapping to kill. Just look out for cats. That never ends well.
Jun 11, 2011. 6:21 AMlegoman111 says:
btw,if u want to eat the bunny then just kill it(although u should have figured that out already).
Aug 3, 2011. 3:10 PMdisturbia says:
animal abuse ^
Aug 5, 2011. 12:43 PMdisturbia says:
Okay then how do you kill them prior to insecticide?
Aug 25, 2011. 4:10 PMgusew says:
Thats whats up.
Jun 20, 2011. 11:07 PMfuzvulf says:
good job.
This is nice, we used to make similar from hollow sections of log when I was a kid. This looks like a lot less work. Plus, given that old forest is next to unheard of around here its pretty hard to find hollow logs anymore :0)
Jun 12, 2011. 7:33 AMgleeflang says:
can you please make a video of this
Jun 6, 2011. 10:53 AMjdavis14 says:
It looks too complicated
Jul 27, 2010. 8:49 AMdumnonni says:
this is an over engineered trap, just get some thin wire and make 10 snares (a noose would be perfect) then check every few hours. if you dont check, a fox will take it or just shred it. when you find a rabbit, break its neck or smash its skull. i tend to skin and gut it on site to attract foxes, that way you could have a nice new fox pelt by the end of the day. alternaitly, a 12 bore to the face does the job.
Jan 18, 2011. 6:27 PMkill-a-watt says:
Snares are unwise in urban areas simply because you can't be sure of killing a bunny or a neighbor's cat.
This is a live trap, so Fluffy from next door can be released alive.
Jan 14, 2011. 7:18 PMoverblast says:
bunny stew.... nomnomnomnom......
Apr 10, 2010. 2:29 PMlemonie says:
A picture of a bunny would really complete this.
Do you take them 5 miles out or eat 'em?
L
Aug 23, 2010. 7:13 PMmrdepo96 says:
Both. Bunny ghosts come back too.
Aug 24, 2010. 12:00 PMlemonie says:
ha, mmm
L
Oct 7, 2010. 8:24 AMh0meIandsecurity says:
wow you are happy people, there where i live arent any rabbits but i would like it has, even on summer holiday because it is borind and i am on village, can u tell me how to find rabbit or attract it (i catched a bird two times, bat one time, frog 1000 times and released them after max 3 days) so i want to attract some animals from forest in my village, how to do that pleaseeeeeeeeeeeee?
Sep 25, 2010. 1:49 PMMikesmith9999 says:
Regarding eating rabbits living in an urban environment: Do they eat in garbage cans? Even if they do, if you clean them properly, does it still create a problem?
Aug 12, 2010. 1:57 PMclemsonguy1125 says:
Good instructable, I made a squirrel trap this same design except used metal heating vent because squirrels chewed through my wooden trap, just with the wire mesh be careful not to use any that contains lead, most of the cheap stuff at Lowes does.
Jul 8, 2010. 7:11 PMRev_William says:
I personally like rabbit lol. But I know what you mean. I used to raise rabbits as a kid, not as pets, for money and food. anybody that has more than one especially aggressive bucks wont think of them as cute lol. At one time I had over 80. Cant afford to buy them anymore may have to start breeding again nieghbors dont like the idea of me culling the hoods herd lol.
Jul 2, 2010. 2:53 PMboneguru says:
excellent job, and yes they are quite tasty, stews, grilled, breaded and fried.
1-40 of 54next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
83
Author:rickharris
Retired technology teacher - 2 kids, aged 62 I have an Hons deg in Design and Technology - 28 years as Computer systems engineer Trained as Electronics engineer in the Royal Air Force
