3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making a Simple Air Core Inductor (Induction Coil)
This instructable will tell you how to make a simple small air core inductor, specifically for Niftymitter. Niftymitter is an open source FM transmitter based on Tetsuo Kogawa's Simplest FM Transmitter,  a free running oscillator circuit, hence the need for a coil.
Step 1What you need
A small reel of enamelled copper wire.
A drill bit of the desired internal diameter of the coil.
Soldering kit and solder.
Wire snips and needle nosed pliers.
For Niftymitter, use 0.75mm (or 22SWG) diameter wire, such as this from Rapid and a 5mm drill bit.
SWG/metric conversions can be found on this page.
16 comments
Dec 1, 2009. 7:39 AMJakeTobak says:
I don't know if it would be more or less work, but you could probably also sand paper the enamel off.
Dec 27, 2011. 3:46 AMsteveastrouk says:
Scrape it with a knife blade is more effective than sandpaper.
Dec 26, 2009. 10:55 PMt.rohner says:
At 100 MHz the current flows only in the outer 10 micrometers of your wire. This is due to the skin effect. So normally i would take a silver plated copper wire for a air coil of this dimension. The windings have to be apart anyway, so i makes no sense to take enamelled wire. By using silver plated wire, you have a lower resistance in the skin region and you don't have the hassle with tinning.
May 17, 2011. 12:15 PMtechno guy says:
How can I make a 1 milihenry air core induction coil? It's for an EMF detector that I might make into an instructable.
Apr 15, 2011. 10:04 AMburdockwing says:
what does an induction coil do?
Jan 7, 2010. 4:40 PMBlofish says:
http://www.66pacific.com/calculators/coil_calc.aspx
inductance calculator
Dec 2, 2009. 12:13 AMagis68 says:
 how do you know the appropriate length and spiral step of any of the coils you ve made??? Do you have any LC meter? be explained
Dec 5, 2009. 5:08 PMrevelae says:
1.598E-002 microhenries, is what this site gives.
Dec 3, 2009. 6:36 AMagis68 says:
electronics-diy.com/lc_meter.php try this you can find it also assembled
Dec 1, 2009. 11:37 AMhivoltage says:
 I like to use my mini torch to burn off the enamel, followed by light sandpaper to get rid of the soot. Makes for a nice clean copper surface that solder tins very easily, especially if you use a little flux.
Dec 1, 2009. 8:48 AMmothflavour2 says:
I find burning it off with a lighter is the best way.  This works really well on headphone wire.  It also gets rid of the reinforcing fibres.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
73
Author:royshearer
I am a freelance design engineer and drummer. My business site is at http://www.zero-waste.co.uk and is often concerned with appropriate technologies, open source design and design for sustainability.
