Making a Simple and Easy Charcoal/ Coal Forge
 by acer73
Step 6: Firing it up
Okay its finally done.
Do not rush especially now when its done.
Were going to fill it up with charcoal about half way to the top and about to 2/3's of the way like in my picture.
Now douse it in lighter fluid and let it get going once its flames have died down a bit turn on the blower and restock the fire and make sure u don't add to much charcoal at a time.
Now heat your metal and forge it
If you want help an how-to's on forging to go AnvilFire
A gas forge can be found Here
And several different types of tongs
Simple
Complex
For more projects and Ideas visit the The Forge Group
This is my first Instructable so give me feed back on its quality
j902771 says: Feb 12, 2010. 9:07 AM
3 or 4 sheets of old dry news paper crumpled in to a loose ball laid in a triangle on top of the forge floor, then if you have any pine cones put a pine cone on top of the paper balls, then put your charcoal chunks or coal up the sides and all over the paper and pine cones,  just cover the whole thing up. then light the paper with a match.  slowly give this some air with your blower,  then a little more air after about 30 seconds,  then a little more,  and so on for about 1 and 1/2 minutes then pore on the air.  fire should be nice and hot.  Have been doing this for about 30 years.  works great.
dogsoldier69 says: Mar 23, 2009. 9:19 AM
LIGHTER FLUID to start the forge?? BAD idea, as putting ANY kind of combustible fluid in to your forge is askin for trouble. Fast, awright...but dangerous?? SURE IS. Better (& more fulfillin, for what that's worth) to start your fire with wood shavins, kindling, then the charcoal/coal , add an air flow & there y'are
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
