This is good for the home hobbyist. If you experience good success and want to try more, I would invest in a professional soil block maker that can do multiples at a time.
See this site for some great advise and ideas on the soil block method. I am not affiliated with it. http://www.pottingblocks.com/ The gentleman who runs the site is very knowledgeable and helpful in returning emails. He also has supplies and square soil block makers at reasonable prices. I learned a lot from all of the content he shares.
Good luck!
Remove these ads by
Signing UpStep 1Parts and tools
2" inside diameter PVC pipe
3/4" wood dowel
circle cutter for use in drill press only
3/4" forstner drill bit
carpet tape
ruler
hand saw - not shown
Polyurethane - water based or similar to seal
3/4" wood screws
3/4" thick wood scrap (I used Pine)
wax (candle)
The drawing shows the idea of the soil blocker. You can start off a seedling in a 3/4" block then transplant to the the 2" block, then a larger block or pot. No shock to roots.
Most pvc products intended for outdoor use, including fence posts, contain LEAD which is used as a stabilzer/UV inhibitor. "country estate" brand PVC fence products, made by Nebraska Plastics, is the only one I know of which is lead-free.
All plastics are known to off-gas and to leach chemicals, as noted in prior posts.
PVC fence components are typically rather thin and will not hold their shape with heavy use as well as aluminum. The exception is the HD gate post that some mfrs (such as CE) offer, which are available in 4" or 5" only.
For these reasons I prefer the aluminum fence posts. It will be harder to cut, but much stronger and safer; well worth the extra initial effort.
Good luck to all. I have run out of scraps due to popular response to my offer.
-Keith R www.TrulyHomeGrown.com
