3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Making a Soil Blocker
  • last photo ←
What are soil blocks? I first learned about soil blocks after watching The Real Dirt on Farmer John movie. He uses them to start seeds and then I saw that Eliott Coleman recommends them. A block of soil is made and with the right mix will hold together during plant root growth. Once the roots grow into it, it will be more solid. It eliminates the need for flats, peat pots, paper pots and any other pot which can get root bound. In the soil block, roots will air prune and not go beyond outside. It is a messy operation, but for those who like to tinker with things in their workshop, I made a 2" and 3/4" blocker to try out. A soil block is supposed to help minimize transplanting shock. Remember that soil blocks can dry out faster than soil in flats or pots. Keep an eye on them.
This is good for the home hobbyist. If you experience good success and want to try more, I would invest in a professional soil block maker that can do multiples at a time.
See this site for some great advise and ideas on the soil block method. I am not affiliated with it. http://www.pottingblocks.com/ The gentleman who runs the site is very knowledgeable and helpful in returning emails. He also has supplies and square soil block makers at reasonable prices. I learned a lot from all of the content he shares.
Good luck!
Step 1Parts and tools
Parts and tools
These are the parts and tools you will need to make:
2" inside diameter PVC pipe
3/4" wood dowel
circle cutter for use in drill press only
3/4" forstner drill bit
carpet tape
ruler
hand saw - not shown
Polyurethane - water based or similar to seal
3/4" wood screws
3/4" thick wood scrap (I used Pine)
wax (candle)
The drawing shows the idea of the soil blocker. You can start off a seedling in a 3/4" block then transplant to the the 2" block, then a larger block or pot. No shock to roots.
21 comments
May 13, 2010. 7:47 AMserpensphile says:
The soil touches the PVC for like 5 seconds when making a block.  Even it touched it for 5 hours it wouldn't off gas enough to introduce anything in the soil that would be harmful.  Then if it did, the chances of the plant absorbing that and it getting back to you is probably nil.
Mar 4, 2009. 7:48 AMchinookbar says:
I wonder if there's a special purpose to the pvc part of this? Such as being smooth so the soil won't stick? The reason I wonder is that I'd like to make a 4" soil blocker to accommodate my commercially produced 2" soil blocker which makes square blocks. We have a farm and square is nice since we do thousands of starts and the squares fill a large flat without wasting space. The commercial 4" blockers cost $100! We might have to go back to using plastic as our tomato and pepper starts get bigger unless we can figure out a functional design for a large square blocker. Ideas and suggestions much appreciated! Thank you!
Mar 16, 2009. 10:54 AMdewilkins says:
If I were looking to make 4 inch square soil blocks I would look at square pvc such as plastic down spouts and pvc post covers uses with pvc fencing.
Mar 8, 2010. 6:26 PMflatwound47 says:
YES, PVC fence posts also come in 4"x4", but several things to consider:
Most pvc products intended for outdoor use, including fence posts, contain LEAD which is used as a stabilzer/UV inhibitor.  "country estate" brand PVC fence products, made by Nebraska Plastics, is the only one I know of which is lead-free.
All plastics are known to off-gas and to leach chemicals, as noted in prior posts.
PVC fence components are typically rather thin and will not hold their shape with heavy use as well as aluminum.  The exception is the HD gate post that some mfrs (such as CE) offer, which are available in 4" or 5" only.
For these reasons I prefer the aluminum fence posts.  It will be harder to cut, but much stronger and safer; well worth the extra initial effort.
Good luck to all.  I have run out of scraps due to popular response to my offer.
-Keith R  www.TrulyHomeGrown.com
Mar 5, 2009. 8:45 AMaeray says:
A chimney flue block (they are fired ceramic hollow squares with rounded corners) might work for a square blocker. I'm not sure if the come in 4" though.
Mar 4, 2009. 12:10 PMSwishercutter says:
Put the end of a length of PVC pipe into a vice, tighten it up, then heat with a torch. Continue tightening while heating, then turn. Keep going until you have somewhat of a square. I have done this before (not for this though). I am not sure what fumes or toxins are released while doing this so make sure you are in a ventilated area, also do at your own risk.
Mar 27, 2009. 5:53 PMkricketone says:
'When PVC is heated it releases clorine gas
Feb 27, 2010. 8:59 PMflatwound47 says:
I build a lot of fences, and of course end up with some scraps on hand.  I made soil blockers from fence posts.  Most residential aluminum fencing (like Jerith or Delgard) uses 2" square posts.  Perfect for the 2" blocks.  Square aluminum posts also come in 1-5/8" , 2-1/2", 3" and 4".  It's light & smooth and isn't PVC, for those concerned about chemical leaching.  If you're not in the fence & gardening business like I am, I bet you could ask nicely & get permission to raid the dumpster of a fence company near you and get what you need.  If you're in central NJ, I usually have some scraps I'd gladly give you for nothing.  Contact me through TrulyHomeGrown.com
Mar 17, 2009. 6:54 AMRanie-K says:
How about attaching these things to the drill-press? Would make pressing easier :)
Mar 12, 2009. 9:55 AMmcenerny says:
Terrific instructible - Just what I was looking for. One suggestion, though. To make it easier to line up the 3/4" hole in the wood circles, first start the disk by using the smaller bit to just mark the center. Then you can use that to line up the 2" hole cutter bit and cut the circles with the center 3/4" hole already marked and started accurately.
Mar 12, 2009. 10:34 AMJason_G says:
This is great! Regarding the soil mix, I wouldn't use peat moss. It has anti-microbial properties (good organic soil is full of beneficial microbes) and a lot of energy is expended with harvesting and shipping it from Canada. There are some additional environmental negatives that I can't recall right now. Other than that, I'm definitely gonna give this a shot. Thanks!
Mar 12, 2009. 7:57 AMcam8122 says:
Hi Dave, Thanks for this. I needed to get off the couch. Jody
Mar 4, 2009. 9:45 AMnolte919 says:
How many cups lime is that in step 6? All I see is a little question mark instead of 1/2 or 1/4 or 1/3 or whatever.
Mar 4, 2009. 10:57 PMKryptonite says:
My mum & I just grow seadlings in small circular pot, plastic of course, then when time to put in the garden we just take the whole "block" out & bury it. Good work on the instructable, it's rather well set out & quite clear.
Mar 4, 2009. 8:20 AMUncle Kudzu says:
a fine and timely instructable! i'll soon be starting some vegetable seeds indoors for later transplant. Good Stuff, Dave!
Mar 3, 2009. 10:22 AMrobert.a.scheffler says:
This is a great idea. I think I will try this and replace my current method of using toilet paper rolls to hold the soil.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:DaveNJ
